engine type 56?
Old Sep 10, 2010 | 08:13 PM
jdubya's Avatar
Default engine type 56?
According to the VIN decoder I found online, my 97 850 GLT VIN indicates an engine type 56. The same VIN decoder doesn't list an engine type 56. It shows 55 and 57 and a couple more that are all in the 50's. Any ideas???
Thanks.
Old Sep 12, 2010 | 08:05 AM
JimKW's Avatar
Pretty sure the 56 means low pressure turbo. I know 57 is High Pressure Turbo and 58 is the R. I'm not positive on this though about the 56. The LPT was only on the 97 model 850 though.
Old Sep 12, 2010 | 04:44 PM
matt01's Avatar
your engine is a b5254T low pressure turbo
Old Sep 12, 2010 | 10:00 PM
turbo matt's Avatar
Ok got a similiar question. Did all 97 850 GLT have light pressure turbo's? Is everything the same (Motor, turbo, trannie) as a T-5 model just pushing less boost becasue of the ECU limiting boost?
Old Sep 13, 2010 | 08:22 AM
jdubya's Avatar
Thanks everyone. Would an ECU from one of the other engines work with this engine?
Old Sep 13, 2010 | 04:35 PM
matt01's Avatar
turbo matt -> No.
the low pressure turbo motor is a 2.4L where as the HPT is a 2.3, the piston sidewalls are thicker so it should be able to handle more boost, but the rods are the same, and they are very similar.
To the OP, yes a T5 or an R ECU should work providing you are motronic 4.3. My cars a 97AWD with a b5254T and im 4.4, not all 97 LPT's are 4.4, you would have to get that checked at a volvo dealer.
Esnyder
Nov 6, 2008 09:41 PM
850TurboWgnPlatEd
Oct 12, 2008 05:51 AM
Bruce
Jul 11, 2008 10:24 PM
jollygoodgold
Jul 16, 2007 12:06 PM
Carvasarus
Jan 1, 2007 06:21 PM
