EVAP engine code question
Old Mar 26, 2008 | 09:09 PM
jmd's Avatar
jmd
Default EVAP engine code question
I've got a '96 855 turbo and a few weeks ago the check engine lite comes on. A friend of mine has a OBDII scanner, read the code as evap, cleared it and it stayed off for a good week of commuting. I thought that was that, but it came back on again today. The only thing i can think of is that i just filled it up with gas yesterday, as i know sometimes it can have something to do with the gas cap not being properly set. Perhaps a new gas cap would do the trick, but i was wondering what other common issues might trigger that code. Any help greatly appreciated. Thanks!
Old Mar 26, 2008 | 10:11 PM
JPN's Avatar
JPN
Default RE: EVAP engine code question
That problem seems to have been caused by either:
- Yes the gas cap.
- Overfilling the tank (when the filling nozzle clicks once, stop fueling further, except whenit clicks 2 seconds after you start fueling[8D]).
If not for those 2, see attached.
JPN
[IMG]local://upfiles/6892/10D8F83E203044E9A88B301E38126450.jpg[/IMG]
[IMG]local://upfiles/6892/754A99A10BFA42218D2DC056A9B2E5DA.jpg[/IMG]
[IMG]local://upfiles/6892/F1FE6F2F0C9F40D182C2C3E205E562AC.jpg[/IMG]
Old Mar 27, 2008 | 08:55 PM
jmd's Avatar
jmd
Awesome...thanks for the response. I'll turn the code off again and make sure not to overfill it. Dont think i have the past two times...usually just pull it out the first time it clicks...but will see. I hope that's all it is.
Old Mar 27, 2008 | 10:58 PM
jnduke's Avatar
JMD,
I've got the same code on my '96, but I'm also getting 'long tern rich mixture.' Plese let us know if you find a solution. My EVAP code read leak somewhere in system. I can't find any abnormality, but I have yet to remove the wheel well and look around the filler neck, which is where I think my problem is. TECH has suggested a bad EVAP valve, but I can't seem to be able to order the parts from anyone, since they never sell them. It is very frustrating. I have also noticed what looks like fuel spillage out of the tank, so maybe my cap is bad. I was going to order one with the new EVAP valve, but no one seems to think that a bad cap could cause a 'Long Term Rich" code.
Keep us posted please!
Old Mar 28, 2008 | 05:33 AM
JPN's Avatar
JPN
Jnduke,
I wonder if the following vendors would have one?
http://www.fcpgroton.com/category-ex...37/by_year/46/
(FCP Groton's older version web page was so much better & easier to use but now they screwed it up and made it into the universal data-base format which bothers me because everyone else uses it[8D]).
http://www.eeuroparts.com/productdet...&code=9014
If I got wrong parts, then search around on those 2 vendors.
JPN
Old Mar 28, 2008 | 10:51 AM
jnduke's Avatar
JPN- that sure looks like it-I'll double check the part number. I had called them and IPD and no one could help me.
Thanks. I've got to start using that website.
skatermattc2
Jan 10, 2020 10:01 PM
chrisvolvo850r
1998-2000 model year V70
Jun 5, 2012 12:05 PM
ionracing
Sep 28, 2011 09:12 AM
Byroni616
Apr 14, 2008 08:10 PM
nbac3k
Nov 20, 2007 06:46 PM
