Fixing a oil pan drain plug
Old Jul 7, 2011 | 03:01 PM
91shelby's Avatar
Default Fixing a oil pan drain plug
What would be the best way to repair a stripped oil pan drain plug WITHOUT replacing the pan?
Old Jul 7, 2011 | 03:58 PM
ibified's Avatar
use a thread tap to make a larger threaded hole, then put in an oversized plug. Some places sell oversize plugs that have the tap built onto the end. install according to manufacturer instructions.
Old Jul 7, 2011 | 04:56 PM
MattyXXL's Avatar
+1 with ibified... we do this to the bikes at the shop all the time.
Old Jul 7, 2011 | 07:21 PM
91shelby's Avatar
any good places i can find one online, problem is its my parents 96 glt in Colorado
Old Jul 7, 2011 | 07:40 PM
clean850R's Avatar
Google time cert! It's a drainplug repair/ replacement for aluminum pans. You install an insert the same as factory but steel. Holds up better we do it all the time at work on the aluminum pans mostly when the crush washers aren't changed in several consecutive oil changes! It works and better than buying a pan!
Old Jul 7, 2011 | 07:43 PM
clean850R's Avatar
Here's a link there is a distributor on the list in Florida!!
http://www.timesert.com/html/distributor.html
brianb
Jan 13, 2010 06:13 PM
jorhyne
Aug 20, 2008 10:54 PM
Mnvolvo1
Mar 20, 2008 07:13 AM
Keith Tobberman
Nov 26, 2007 12:35 PM
wheelsup
Nov 7, 2007 02:26 PM
