Steering Wheel Removal Going South
Old Jul 7, 2011 | 11:57 AM
vjaneczko's Avatar
Default Steering Wheel Removal Going South
I'm trying to fix the squeaky dash and I'm getting stuck with removing the steering wheel. I'm stripping the Torx bolts that hold the airbag in place.
Anyone know if I can drop the steering wheel rack/frame/whatever its called to remove the dash? Would it be difficult or ill-advised?
Old Jul 7, 2011 | 05:20 PM
boxpin's Avatar
The two bolts under the dash drop the column. You should be able to just do that.
Are you removing the dash pad or the entire dash? Just wondering cuz you can remove the pad without removing the wheel.
Old Jul 7, 2011 | 09:15 PM
vjaneczko's Avatar
Thanks! It looked like that was an option but I didn't want to try something 'new' without checking first.
I'm pulling the whole thing - I want to fix the mounting tabs at the firewall.
Martinsea
Apr 12, 2014 09:02 PM
dobrosailor
Jan 16, 2010 10:21 PM
dobrosailor
Jan 12, 2010 06:20 AM
daver80
Jun 29, 2009 03:01 PM
XSive
Jun 20, 2007 05:15 PM
