Flash tuner for 850
Old Aug 20, 2010 | 10:20 PM
turbo matt's Avatar
Default Flash tuner for 850
Is the reason we can not get a flash tuner instead of sending the ECU off to be remapped is because it is not OBD II compliant?
The OBD port would be so much more useful if you wanted to do your own tuning!!
Old Aug 21, 2010 | 02:22 AM
ibified's Avatar
I dont know about your car, but mine is OBDII compliant.
Old Aug 21, 2010 | 03:14 AM
ShaginWagon's Avatar
No. it's because in the older cars they use hard written eeproms.
These are written by dedicated eeprom burners controlled via a pc and associated software.
I had a car once that could be flash tuned, late model (2006) mazda.
It has a software problem. They couldn't fix it. Even after two years they couldn't fix it.
Will never own another mazda/ford based product again.
Do it right or go home..
Old Aug 21, 2010 | 03:26 AM
Mad Matt's Avatar
I had a '93 854 donor car for my manual swap that did not have an OBD II port. It was in '96 (IIRC) that OBD II mandate came into effect.
I'd just send your ECM to iPd, have them update with the tune, and there you are. It's totally worth it!
Old Aug 21, 2010 | 11:12 AM
fcpgroton's Avatar
Former Sponsor
I would do what I did and search the forums for someone selling a tuned ECU. Not only will you get the same tune for half the price most of the time, but you will not have any downtime waiting for the tuned ECU to be mailed back to you.
Old Aug 21, 2010 | 03:01 PM
turbo matt's Avatar
Well I thought about that but I thought it was hard coded to the car or something along those line's. They are always asking for the numbers off the engine or something.
Old Aug 21, 2010 | 03:23 PM
Mad Matt's Avatar
In The new cars the ECU's are VIN locked to the car.
With the 850's you can swap ECU's as long as it has the same number's on it. I don't remember the details but there have been ECU's up for sale on VS as of late.
Old Aug 21, 2010 | 05:00 PM
boxpin's Avatar
Yes, its available....Turbo Tuner.
http://www.turbo-tuner.co.uk/
philnort
Jan 18, 2008 08:08 PM
mcguij1
North East
Dec 11, 2007 01:58 PM
flamejet
Sep 6, 2006 08:28 PM
maxstar3
Nov 18, 2005 07:35 PM
grochef
Sep 8, 2005 12:14 PM
