Headlights won't come on
Old Dec 29, 2011 | 10:39 AM
BIGRED59's Avatar
Default Headlights won't come on
94 850 wagon the lights won't come on with the switch they work if you hold the dimmer switch up. I've replace the dimmer switch and the main headlight relay still no help Is there another relay somewhere or ?
Old Dec 29, 2011 | 12:01 PM
Maybe the main switch is bad. The do come apart in the back. You can simply pull it out (or push it from the back of the switch), unplug it and see if it's falling apart. I have one if you need it. Just let me know.
Old Dec 29, 2011 | 01:09 PM
The headlight switch itself is just on/off. If you can get the lights to come on when you pull up on the lever you are probably seeing the high beams, the ones closest to the radiator. That means you're getting power through the headlight switch and to the dimmer switch on the steering column.
Any chance it's just the bulbs burnt out? Have you tried to check the headlight sockets with a test light or voltmeter to see if there is voltage there?
Old Dec 29, 2011 | 02:13 PM
BIGRED59's Avatar
No the low beams come on also when you used the dimmer switch when the light switch is in the on position
Old Dec 29, 2011 | 02:15 PM
When the back of my head light switch fell apart the high beams still worked but the reverse and head lights did not.
Old Dec 30, 2011 | 10:01 AM
If the low beams come on but only when you pull up on the signal lever it sounds like the replacement switch might be bad.
and240res
Aug 25, 2012 01:06 PM
Coach Dad
Jul 27, 2011 06:26 AM
VDriver24093
Feb 21, 2011 04:35 PM
lipsro1
Jul 31, 2010 01:39 AM
floryed
Apr 13, 2005 01:31 AM
