Heater vent selection not working.
Old Dec 18, 2012 | 08:59 PM
Sean Berger's Avatar
Default Heater vent selection not working.
Hey guys. Just did a head gasket on my 97 850 T5. The heat works great. but all the air just blows out all the vents, no matter which is selected. Is this vacuum operated? if so, where is the vacuum line? After I got everything back together i do have one really long and thin black vacuum line left, but I cant find where it goes for the life of me. I'm assuming this is my problem, but any other help would be great. Thanks guys!
Old Dec 19, 2012 | 07:07 AM
LOL, nothing under the hood will effect the vent controls inside.
The system has a bleed door. Sometimes the plastic gear/arm breaks.
Old Dec 19, 2012 | 10:38 AM
JPN's Avatar
JPN
Depends on whether you have ACC or MCC; see attachment. Considering the trim level, I assume you have an ACC, in which case the damper motor(s) may need adjusting.
JPN
Attached Thumbnails Heater vent selection not working.-850-ac-damper-motor.jpg   Heater vent selection not working.-850-mcc-1-.jpg   Heater vent selection not working.-850-mcc-2-.jpg
Old Dec 19, 2012 | 03:42 PM
The MCC, manual climate control will have a fan speed switch with 4 speeds and the temperature control ***** go cool to hot. The ECC, electronic climate control will have a slider for infinite fan speeds and the temperature control ***** will have numbered temperature selection.
Attached Thumbnails Heater vent selection not working.-heat-ac-mcc-panel.jpg   Heater vent selection not working.-heat-ac-ecc-panel.jpg
Old Dec 19, 2012 | 04:16 PM
94850Turbo's Avatar
where exactly is that bleeder arm/gear? i have the same problem with my ECC in my 940 850 turbo
Old Dec 19, 2012 | 05:03 PM
Under the glove box, just to the left of the blower motor. You need to pull the panel under the glove box to see it.
Attached Thumbnails Heater vent selection not working.-heat-ac-close-up-recirc-morot-arm.jpg
Old Dec 19, 2012 | 08:30 PM
94850Turbo's Avatar
ok thanks, so that would be the culprit of not being able to select where the heat is distributed?
Old Dec 19, 2012 | 08:35 PM
If it's broken, yes.
Old Dec 19, 2012 | 08:37 PM
94850Turbo's Avatar
thanks..hopefully i can look at it tomorrow!
Old Dec 20, 2012 | 01:16 PM
It's an ECC unit, I was under the impression that the "door" to route the air was controlled by vacuum. Thanks for the advice, ill dig into it here soon and let you all know!
Old Dec 20, 2012 | 03:44 PM
boxpin's Avatar
No, that arm controls whether air comes in from outside or recirculates.
Old Dec 20, 2012 | 06:27 PM
Originally Posted by Sean Berger
It's an ECC unit, I was under the impression that the "door" to route the air was controlled by vacuum.!
Unfortunately the ECC uses little motors to move the doors.
Attached Thumbnails Heater vent selection not working.-heat-ac-blend-door-motors.jpg
Old Jul 14, 2016 | 08:11 AM
Zydrius's Avatar
Hello,
I have Volvo 850 1996 m. I want to ask, how close the "Air through panel vents ", because when i switch to the another function selector, the air coming out the same from panel vents. It is should be a damper motor? And where he is? How close?
http://new.volvocars.com/ownersdocs/...ages/fff74.jpg
https://volvoforums.com/forum/attach...oor-motors.jpg
Tanks for answer.
Old Jul 14, 2016 | 08:34 AM
firebirdparts's Avatar
There is a wheel for that on the dash. This wheel is beside the center vent. That may not be your problem, but it is a strange feature that other cars don't have. Volvo 850 has this strange wheel that sends cold air to the center vent while the heater is set for another function.
Old Jul 15, 2016 | 10:37 PM
97-850Wagen's Avatar
Hmm...good to know lol. Mine sends "cold" (outside "fresh" air) to all the vents when I run that wheel up...Guess I better add that to my "investigate this problem soon" list That coupled with only having one speed (high) for the fan (on an ECC unit) no matter where I put the slider when the heat is on (but not AC), looks like I'll have my work cut out for me with HVAC repairs before winter...Wonder if its a failing blower motor resistor Pulled a spare from the scrapyard, just haven't taken time to install it...
Old Jul 21, 2016 | 06:28 AM
Zydrius's Avatar
My problem looks like that:
Old Jul 21, 2016 | 09:54 AM
  #17
Okay so you have a more serious problem
Old Nov 16, 2017 | 08:58 PM
  #18
Tangora's Avatar
Default It's the dial
I am trying to find the replacement dial for that myself. I have a 97 850.
You can squeeze the dial and pull it directly out. Inside of it there is a small metal clip that has become bent. I don't know how it is supposed to look or where to get a replacement, but that little piece has to be bent back into some shape in order to turn the dial.
Let me know if you figure out where to buy one or what shape it should be.
rspi
May 15, 2014 07:36 AM
chadman551
Oct 11, 2009 08:46 PM
mikebs70
Nov 26, 2008 08:01 AM
BigAdam
Oct 21, 2008 10:01 AM
