I'M SO LOST! HELP!!
Old Jan 22, 2006 | 05:27 PM
jayad's Avatar
Default I'M SO LOST! HELP!!
Well, I took the valve cover off to check to see if the pistons/lifters were stuck and none of them were. I don't understand why my friggin' car won't start. Timing, spark, everything is checking out. I think that possibly the Knock Sensor and the Mass air flow sensor (computer says). If I replace these two sensors, what is the possibility that the car will start? Should I just sell the thing to a parts junk yard, or what?????
Old Jan 22, 2006 | 05:37 PM
rp850's Avatar
Default RE: I'M SO LOST! HELP!!
No idea what your odds are for replacing those sensors. Knock sensors are a pain because they're under the intake manifold. You have fuel pressure at the fuel rail, right?
Old Jan 22, 2006 | 06:10 PM
jayad's Avatar
Yes! I've got it all. It all comes back to those sensors. Does anyone know of any ideas for web sites where it shows the different engine parts. I need to know EXACTLY where and how to get to the knock sensor to check and/or replace it. Also, if anyone could run over the syptoms of a shot Mass air flow sensor, that would be great, too. Thanks!!
Old Jan 22, 2006 | 08:02 PM
If you unplug the mass flow then it should start if it is bad.
I haven't ever seen knock sensors not let a car not start.
I would not worry about the knock sensors now. I would worry about the mass flow.
koster
Oct 11, 2009 08:19 AM
mdanzigmick
Aug 13, 2009 05:22 PM
Need4Svede
Jul 27, 2009 12:54 PM
digimower
Aug 17, 2008 12:55 PM
rp850
Jul 22, 2005 03:36 PM
