Infinity Basslink Question
Old Jun 1, 2009 | 11:31 AM
summit's Avatar
Default Infinity Basslink Question
Have a quick question. I bought an Infinity basslink and I have a SC-815 HU. Is the AMP out on the back just a low level audio source? And do I just need a 6pin DIN to RCA adapter? And if so where do you get those, like can you go to car toys or is more like a special order thing?
Thanks for the help.
Old Jun 1, 2009 | 11:55 AM
Systek's Avatar
year/model?
Old Jun 1, 2009 | 11:59 AM
Systek's Avatar
not sure if this is the right one but you can call to installer.com. they are a local shop here in houston and have great customer support...
http://www.installer.com/item/displa...php?it=70-9220
Old Jun 1, 2009 | 12:13 PM
summit's Avatar
Its a 1996 Volvo 850. No GLT or Turbo. I added the premium sound system SC-815. It used to be just the tape deck and radio model. And I still want to use the stock speakers and HU's amp for the speakers. Just want to add the basslink for now.
Old Jun 1, 2009 | 12:32 PM
Systek's Avatar
i am not familiar with it but call them. they may still be able to help you. It's a free call so it doesn't hurt to call.
Old Jun 1, 2009 | 01:44 PM
mkc70's Avatar
Buy or make the DIN to RCA adapter for audio signal to the Basslink. Basslink can also use high level input wires from a pair of speakers(typically rear ones,closer to the equipment). Remote turn on can be run from antenna output of amp or middle pin of DIN cable. IIRC, if you remove the yellow shunt on the harness it will auto turn on when receiving an audio signal so you would not need the remote wire hooked up. Good luck.
96850urbo
Jan 23, 2009 01:00 PM
Adrenalin540
Dec 31, 2008 10:19 AM
Aaronius
May 30, 2008 06:10 PM
pvolvoman
Oct 24, 2007 07:29 PM
mordezmoncou
Apr 9, 2007 05:22 AM
