Key gets very hot
Old Dec 28, 2006 | 06:12 PM
axelm's Avatar
Default Key gets very hot
When I stop the car and remove the key from the ignition I usually notice that the key is very hot, about 50-60 degrees celsius. Is that an indication of a faulty ignition switch? I don't have any electrical problems in the car that I know of.
Regards
Old Dec 29, 2006 | 10:10 PM
Default RE: Key gets very hot
Could be what is the temp outside?
Old Dec 30, 2006 | 06:47 AM
axelm's Avatar
32 celsius
Old Dec 30, 2006 | 09:54 AM
JPN's Avatar
JPN
Hello Axel,
32C shouldn't make the key that hot at all. Are there any other parts thatarehot around the ignition switch?There may be ashort circuit, though usually fuseblows first.
I haven't heard of this problem, so a bit more research may be required. But as long as you don't see smoke or smell something like melting plastic, it's probably ok.
JPN
Old Dec 30, 2006 | 12:32 PM
32 might make it a little warm but shouldn't be HOT.
Old Jan 2, 2007 | 01:54 PM
axelm's Avatar
I just came back from New Year's vacation, and I travelled with my other car since the 850 A/C isn't working. I'll be monitoring the key temp a bit closer and posting here again.
Thanks
bigdaddyrdpjr
Jul 8, 2010 11:01 PM
jefef
Jun 19, 2009 01:08 PM
beardo265
Sep 27, 2007 09:24 AM
vtech22
Mar 2, 2006 01:09 AM
