long starts
Old Dec 1, 2010 | 12:20 PM
I am Phil's Avatar
Default long starts
when I start my car i have to hold the gas down to the floor (aprox 10 secs) or it may not start. Once and a while it starts on a dime or if it has just been running. I just bought an 02 sensor as it has been running super rich and my milage has hit the the floor. But i doubt this has anything to do with it . But it may have to do with the computer, someone told me as it may be confuzeled but...
Old Dec 1, 2010 | 09:58 PM
gdog's Avatar
Does it crank slow? My starter got "tired" after about 130K mls and I was having intermittent hard starts; rebuilding the starter fixed it!
Old Dec 1, 2010 | 10:19 PM
740_300K's Avatar
Having to add throttle on start may indicate that the fuel pressure regulator has failed. When the FPR in my 740 failed, it ran rich. Pull the vacuum hose off the regulator, and look/smell for fuel. If there is ANY, replace the fuel pressure regulator first.
Old Dec 1, 2010 | 11:17 PM
boxpin's Avatar
You should never have to touch the throttle to start a fuel injected car.
Old Dec 2, 2010 | 12:10 AM
740_300K's Avatar
Exactly. Needing to would indicate a bad FPR, maybe a bad MAF (will set a check engine light), or something like that.
Old Dec 2, 2010 | 01:30 AM
ibified's Avatar
I vote for bad FPR as well.
Old Dec 2, 2010 | 08:27 PM
I am Phil's Avatar
Thanks I will check it out. Does wacking the cat affect anything?? My friend says its plugged (idk how he knows) but It does smell bad... Not as bad as before the 02 sensor was replaced. It is much better now, altho CEL keeps going on and off. Maf was replaced(used) THANKS for the response very new too all this stuff. IAP
Old Dec 3, 2010 | 09:18 AM
Rickford's Avatar
Cat's used to get plugged when peps would burn regular LEADED fuel in their "unleaded only" vehicles, it was cheaper, bet it's not plugged.
silviamft
Feb 22, 2011 12:30 PM
KatieK
Nov 11, 2010 10:29 PM
turbo940
Mar 29, 2008 07:18 PM
Uhills
Apr 5, 2005 08:22 PM
TexasProud
Dec 3, 2004 03:37 PM
