Messed up timing
Old Jun 9, 2021 | 09:06 PM
gruey15243's Avatar
Default Messed up timing
So I’m almost done with my timing belt job and did a huge mess up at the beginning. I forgot to align the timing before hand and I’ve already replaced all the parts (water pump, pulleys,tensioner, etc.) I tried to rotate the engine but I think I messed up the cam shaft timing as well? Does anyone know how to fix it before I put the belt back on? I already got the belt on through the bottom, but I don’t want to continue while I still have to fix the timing. Any help is appreciated!!
Old Jun 10, 2021 | 10:16 AM
firebirdparts's Avatar
They were intended to be locked on the back end of the cam and the crank was locked using a pin under the starter. I don't have any of the special tools for that, though, and I always go by the timing marks. This doc here does a good job of showing the timing marks, but the crank is a little tricky.
https://www.volvoclub.org.uk/tech/se...cyl_vin_55.pdf
You'll find a ton of threads on the timing belt and lots of youtube videos. It was the most discussed repair procedure back when these cars were common daily drivers.
If you are concerned mainly about the rotation itself, all I can say is be careful. If something hits, you'll know. In theory, the crank "locked" position was safe; none of the pistons at TDC. I don't guarantee that.
gruey15243
May 24, 2021 09:00 PM
willbr
Sep 17, 2017 12:36 PM
ibified
Sep 1, 2010 08:48 AM
elizabethera
Jun 24, 2009 05:21 AM
johnhon
Jan 6, 2009 10:02 PM
