msd vs volvo oem
Old Oct 27, 2009 | 10:07 PM
850tony's Avatar
Default msd vs volvo oem
has any one has any experience with the msd coil on the 850? is there much of a diff?
thanks
tony p
Old Oct 27, 2009 | 10:12 PM
I hear it is not worth it.
Old Oct 27, 2009 | 10:14 PM
850tony's Avatar
if it worth if it if i need to replace it anyways?
Old Oct 27, 2009 | 10:29 PM
You can do it. I hear it really does not help that much. But give it and shot. I think you can find them for like $5.00 or $10.00 more.
There is one for sale on VS right now.
Old Oct 28, 2009 | 03:33 AM
ShaginWagon's Avatar
an ignition coil will only generate as much voltage as is needed by the spark plug to fire.
So you could have a 100,000 volt (rated) coil, but if the engine is only needing 5,000v to fire, thats all you'll get.
chances are the lower impedance and hence higher current draw may actually hurt the oem transistor.
most modern systems are more than enough for even hard street demands.
The actual MSD box's (6a etc), now thats a different story.
Old Oct 28, 2009 | 07:38 AM
boxpin's Avatar
I have one and have not noticed a bit of difference other than I feel cool having one. So if you want to feel good and have a nice looking add on under the hood plus the $40 to spare...go for it. Performance wise...not noticable.
Old Oct 28, 2009 | 07:44 AM
gilber33's Avatar
I have read that the OEM is actually better than the MSD.
Old Oct 28, 2009 | 10:44 AM
fcpgroton's Avatar
Former Sponsor
+1
The stock coil is more then powerful. If your stock coil has gone bad, then get the MSD. Otherwise, don't waste your money.
Old Oct 28, 2009 | 06:08 PM
Carrots's Avatar
Adding voltage to the ignition system will only help if you're firing worn- out pugs and bad wires. Or if you're driving a car that makes like 1,000 HP out of 2.0 liters. Really heavy loads require more voltage to be able to fire. For a Volvo 850? There's no point in paying the extra for the MSD, unless you simply want it to look cool. And there's better ways to do that, too.
Old Oct 28, 2009 | 06:15 PM
gilber33's Avatar
Paint your oem coil orange and write MSD with a sharpie on it, or any three letters you want for that matter.
Old Oct 28, 2009 | 07:46 PM
Carrots's Avatar
I was thinking "better ways to make your engine compartment/ car" look cool. Not your coil. Though I suppose that would work, too
Old Oct 28, 2009 | 08:02 PM
gilber33's Avatar
I know. I agree though, if your going for aesthetics, then MSD ftw.
Actually if you go through FCP the oem coil is actually more than the MSD from IPD. I withdraw my statements and get whatever you want. I would still go oem.
850T5M
Apr 26, 2014 08:13 PM
ABVO850
Feb 9, 2013 07:44 PM
850R_black_edition
May 8, 2012 01:03 AM
pezwack
Jun 22, 2011 06:57 AM
Volvo V70R
Jan 26, 2008 10:09 PM
