mystery vacuum line?
Old May 6, 2011 | 03:00 PM
rcvolvo's Avatar
Default mystery vacuum line?
While changing the air filter I noticed a small black vacuum line coming off the side of the filter housing, for the life of me I cannot find where it connects. The bend in the hose looks like it was going some where under the rotor cap. I removed the cap and nothing. This is driving me nuts! Can anyone check theirs and trace it for me? The line is only about 6 or 8 inches long and curves under the rotor cap. Thanks!
Old May 6, 2011 | 03:13 PM
Pic???
Old May 6, 2011 | 04:53 PM
rcvolvo's Avatar
Default rspi
Sorry, I don't know how to send pictures. If you look straight down on the air filter on the right hand side you will see two small hoses going into the air filter. On mine one is white that snakes up towards the radiator the other is black and curves as if it was connected somewhere under the rotor cap.
Old May 7, 2011 | 01:23 AM
blackbrick's Avatar
check my posts in this link and this link
Old May 7, 2011 | 01:50 AM
91shelby's Avatar
pics would help for sure, is the car a turbo?
Old May 7, 2011 | 08:46 AM
Henry10's Avatar
You need to take time to find and read your Vacuum Diagram, which should be a tag in your engine compartment. Then follow each line and check / replace if not good enough.
When I originally bought my 855 and went through the same exercise, I found some things not connected correctly, although lines were like-new.
There is a thread here (maybe 20 threads actually) about these vacuum lines around the Airbox.
Actually an important question for you -- is your car Turbo or not (very different Vacuum schemes)?
Old May 7, 2011 | 09:41 AM
If it is a black hard line that attaches to the lid on one side the other side should go to the front of the air box. It will go to the valve for the air inlet from the core support. The nipple on the air box is a little hard to see though.
Old May 7, 2011 | 12:24 PM
rcvolvo's Avatar
Default vacuum line
Non-Turbo. checked pics in this thread and can not find nipple.
Old May 7, 2011 | 01:36 PM
You almost have to pull the air box out to see it if you do not know where it is.
Old May 7, 2011 | 02:39 PM
tony1963's Avatar
It is the vacuum line for the heated air intake off the manifold.
Old May 7, 2011 | 02:57 PM
jxkeefe's Avatar
No, it comes from a thermostat on the air box. The other side of the thermostat goes to the intake manifold port. On my 1996 850, the white plastic tube goes to the black colored fitting on the thermostat and the black plastic tubing goes to the brass colored fitting. The other end of the white tubing goes to the intake manifold and the other end of the black tubing goes to the heated air door. jxkeefe
Old May 7, 2011 | 05:23 PM
blackbrick's Avatar
here is pic
Old May 13, 2012 | 05:17 PM
cheapvolvo's Avatar
hello everyone. I just completed a valve job on a 1997 850 na, and I have one mystery vacuum line myself.
It is the small black one on the left side of the intake manifold. It comes snaking its way to the front over by the battery. I replaced all of the other lines to their locations. help would be appreciated.
Old May 13, 2012 | 08:40 PM
mikwik's Avatar
1996 850 glt na / mine goes to the flame trap cover (behind the air tube that goes from the air box to the intake)
OMGitsnickels
Jan 11, 2014 07:36 AM
ABVO850
May 29, 2011 09:44 AM
Ghost Brick
Mar 19, 2011 08:22 PM
Ghost Brick
Nov 8, 2010 02:05 PM
cool_kyle_3000
Oct 19, 2005 01:13 AM
