need help with my 94 850 turbo
Old Mar 2, 2012 | 01:39 AM
evarklier's Avatar
Default need help with my 94 850 turbo
I recently bought a used 94 850 turbo with 112000 miles...cars acting weird now, engine shakes sometime...seems to bog off a take off...at wot the car will sometime seem to have no power, then it'll lung forward like it has power.....car also falls flat on its face at 4 or 5k rpm then pull again after that...wen it hesitates at 4 or 5k I can feel the engine shake....I need help, can't seem to figure it out
Old Mar 2, 2012 | 07:44 AM
gabyman97596's Avatar
Scroll down on this link to the routine tune up items and start from there also retreive the codes from the obd1 port.
https://volvoforums.com/forum/volvo-...s-s-v70s-9266/
Old Mar 2, 2012 | 10:14 AM
nitrosport's Avatar
got the engine light on? check the codes.
could be vacuum leak. could be plugs/wire/cap/rotor.
when i 1st got mine it was sluggish on take off...and then at 3-4k rpms it would studder (when boost came on) plugs/wires/cap/rotor fixed the issue for me. Studdering can be a misfire issue. And not making power when the boost comes on can also be misfire...or engine running rich....or turbo not making proper boost.
Get the codes.
check over the plugs/wires/cap. look for cracks ect. if they seem old, just replace them. Itll run you $150 for those parts, but its a worth while tune up even if it doesnt solve your problem.
Look over vacuum hoses. There are plenty of them under the hood, but even 1 missing/broken will cause plenty of issues.
What does your boost gauge do? If it stops building boost early then that can be a clue a tuneup is needed.
Old Mar 2, 2012 | 11:23 AM
+1 With Gaby.
Old Mar 2, 2012 | 12:30 PM
evarklier's Avatar
There's no check engine light ... I replace the spark plugs *problem remain*...I pulled the wires n OMG one of them had cobwebs on it lol..I'll try what nitrosport says and replace the cap,rotor n wires...if that don't work I'll get back to you guys...thanks *and one more problem, my boost gauge is stuck in the middle, I bought it that way...never got around to fixing it, so I have no idea if I'm actually getting full boost*
Old Mar 2, 2012 | 03:03 PM
Try doing this. https://volvoforums.com/forum/volvo-...working-29883/
Theres a sticky for DIY repairs that helps a lot
https://volvoforums.com/forum/volvo-...repairs-26114/
Old Mar 2, 2012 | 05:53 PM
evarklier's Avatar
K thanks
Old Mar 2, 2012 | 06:32 PM
Lol
trix334
Oct 24, 2010 10:52 PM
Sanel30
Feb 18, 2010 09:16 PM
chef
May 19, 2009 05:57 AM
Cowboy642
Oct 15, 2007 06:33 PM
jiggadude
May 2, 2007 02:53 AM
