Hot Topics - Helpful Information - "How To" DIY Repairs
Old Jan 2, 2009 | 10:24 AM
JimKW's Avatar
Thumbs up Hot Topics - Helpful Information - "How To" DIY Repairs
This is a list of many 850 write ups. I encourage you to read through the entire thread before you start link jumping.A/C Compressor Clutch Re-shimming
A/C Compressor Clutch Reshimming - Volvo Forums - Volvo Enthusiasts Forum
A/C Cuts Out
https://volvoforums.com/forum/volvo-...uts-out-42326/
ABS Controller Cover Removal
ABS Controller Cover Removal - Volvo Forums - Volvo Enthusiasts Forum
Alternator Replacement
Video: https://volvoforums.com/forum/volvo-...850-s70-69318/
Antenna Mast Replacement
Video: https://volvoforums.com/forum/volvo-...67/#post348388
Antenna Switch Writeup - Installing One If You Don't Have One
power antenna switch write-up - Volvo Forums - Volvo Enthusiasts Forum
Battery Drain Diagnosis
Basic Battery Drain Troubleshooting - 101 - Volvo Forums - Volvo Enthusiasts Forum
Blower Motor Replacement 850's
http://www.matthewsvolvosite.com/for...hp?f=1&t=19322
Brake Pad Replacement, Front
Brake pads, front, replacement instructions on a 1998 S70 Volvo, also 850
Brake Pad Replacement, Rear
Brake pads, rear, replacement instructions on a 1998 S70 Volvo, also 850
Buyer's guide for people seeking to purchase a 850
Buyer's guide - Volvo Forums - Volvo Enthusiasts Forum
C/V Axles Removal
Removing the C/V Axles - Volvo Forums - Volvo Enthusiasts Forum
Cabin Air Filter Replacement
Cabin air filter replacement for the Volvo 850 and S70 - Volvo Forums - Volvo Enthusiasts Forum,
Video: https://volvoforums.com/forum/volvo-...t-video-68686/
Cam Sensor - How To Test It
https://volvoforums.com/forum/volvo-...voltage-56508/
Center Console Removal Instructions
How To Remove Center Console - Volvo Forums - Volvo Enthusiasts Forum
Cooling System Overview - NA
Cooling System Overview On A Volvo 850,
Video: https://volvoforums.com/forum/volvo-...68/#post348390
Coolant Hoses, Replace them before they burst
https://volvoforums.com/forum/genera...em-asap-74508/
Compression Test - How To
Compression test on a Volvo B5254 motor, 850 and S70 - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...0-video-71713/
Control Arms - How To Replace
http://volvospeed.com/vs_forum/topic...-installation/
Cruise Control Not Working
Cruise Control Not Working - Turbo Boost Gauge Not Working - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...0-video-71945/
Cup Holder Replacement
Video: https://volvoforums.com/forum/volvo-s70-33/volvo-850-s70-v70-cup-holder-replacement-video-70069/#post348393
Dash Pad Removal (To replace the instrument panel lights)
Removing the dash Pad (To replace the instrument panel lights) - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...l-video-73586/
Diagnostic Trouble Codes (DTC) List
List of diagnostic trouble codes (DTC) - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...0-video-71834/
EGR Removal and Cleaning
Volvo Performance Repairs And Modifications
Evaporator Replacement Instructions
Evaporator replacement instructions - Volvo Forums - Volvo Enthusiasts Forum
Fuel Pump Removal - Replacement
http://www.matthewsvolvosite.com/for...?p=56515#56515
VIDEO: https://volvoforums.com/forum/volvo-...t-video-75624/
Gas Tank Removal
https://volvoforums.com/forum/volvo-...ix-pics-55740/
Glove Box Stuck Closed - How To Open
How to open A broken Glove Box!! - Volvo Forums - Volvo Enthusiasts Forum
Head Gasket Replacement and Related Items
https://volvoforums.com/forum/volvo-...ts-pics-44879/
Video: https://volvoforums.com/forum/volvo-...t-video-74852/
Headlight Wiring Repair
Headlight wiring repair - Volvo Forums - Volvo Enthusiasts Forum
Heat Not Working
Video: https://volvoforums.com/forum/volvo-...c-video-73824/
Heated Seats Not Working
Heated seats not working. Fuse is good - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...0-video-74349/
Heater Core Replacement
Video: https://volvoforums.com/forum/volvo-...70/#post348396
Hood will not open, release cable may be broken
https://volvoforums.com/forum/volvo-...od-open-35736/
Horn stuck on?
Horn stuck on? - Volvo Forums - Volvo Enthusiasts Forum
Instrument Cluster Lighting Diagnosing
Diagnosing Instrument Panel Lights Not Working - Volvo Forums - Volvo Enthusiasts Forum
Key stuck in the ignition - Will not come out
https://volvoforums.com/forum/volvo-...key-out-56392/
Video: https://volvoforums.com/forum/volvo-...t-video-75988/
Keyless Entry System - After Market
Aftermarket Keyless entry system - Volvo Forums - Volvo Enthusiasts Forum
Keyless Remote Control Programming - '95 850 (may work on '93 - '94's also):
Keyless programing how I did it on my 95 850
Maintenance Questions From New Volvo Owner
New Volvo 850 Owners - Read This Important Thread... (Also applies to S/V70's) - Volvo Forums - Volvo Enthusiasts Forum
MCC Removal
MCC removal - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...c-video-75990/
Misfires, troubleshooting
https://volvoforums.com/forum/volvo-...r-posts-70029/
Video: https://volvoforums.com/forum/genera...m-video-75991/
Motor Mount Replacement - Front Lower (Right)
http://www.atthetipwebs.com/technolo...ount_right.htm
Video: Right lower motor mount replacement instructions for Volvo 850 - Volvo Forums - Volvo Enthusiasts Forum,
Motor Mount Replacement - Upper
http://www.matthewsvolvosite.com/200...w-oem-bushing/
Video: https://volvoforums.com/forum/volvo-...c-video-75992/
Motor Mount Replacement - Fwd / Aft Hydraulic
https://volvoforums.com/forum/volvo-...acement-26094/
Odometer Broken, Does Not Count Mileage - How To Repair
How to Repair a Broken Odometer - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...r-video-74301/
Odometer Broken, How To Get Actual Mileage for 93-95 850 Volvo (OBD-I Port)
How to Get the Actual Mileage on a 93-95 850 Volvo - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...01/#post377407
Oil Pan O-Ring Installation Instructions
Oil pan o-ring installation instructions - Volvo Forums - Volvo Enthusiasts Forum
Owners Manual - On-line for all models
http://www.volvocars.com/us/top/yourvolvo/volvo-vehicle-information-library/Pages/default.aspx
PCT Removal and Cleaning
http://www.matthewsvolvosite.com/for...hp?f=1&t=28415
PCV System - Good Writeup With Pictures
PCV Breather System Replacement - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...t-video-74990/
PCV System For Beginners
A how to for PCV system for beginners - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...90/#post377409
Progression and Upgrades - Tech's Yellow T-5R
My progression and upgrades - Volvo Forums - Volvo Enthusiasts Forum
Progression and Upgrades - Tech's Wife's Car
Wife's car progression and upgrades - Volvo Forums - Volvo Enthusiasts Forum
Radiator Replacement - Non Turbo, Automatic
1997 Volvo 850 Non turbo automatic radiator write up - Volvo Forums - Volvo Enthusiasts Forum
Video (Turbo): https://volvoforums.com/forum/volvo-...o-video-71871/
Radio Bulbs - Replacing
Radio Lights - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...e-video-71530/
Radio Wont Come One - Where Is the Security Code?
https://volvoforums.com/forum/volvo-...battery-52074/
Video: https://volvoforums.com/forum/genera...0-video-70284/
Repairs / Improvements and Other Things People Have Done - Includes Timing Belt Change Instructions
Members Write ups - Volvo Forums - Volvo Enthusiasts Forum
Resources Thread VolvoForums
VolvoForums Resources Thread - Volvo Forums - Volvo Enthusiasts Forum
Roof, ceiling liner removal
Video:
https://volvoforums.com/forum/volvo-...04/#post381683
Seat Back Cable Repair For 850
850 Seat back cable repair - Volvo Forums - Volvo Enthusiasts Forum
Video: https://volvoforums.com/forum/volvo-...r-video-74015/
Serpentine Belt Replacement On the 850
Service Light - How To Reset On The 850's 93-95 Models
How to reset the SERVICE LIGHT on the '93 through '95 models... - Volvo Forums - Volvo Enthusiasts Forum
Shift **** Removal/Repair - Manual 5 Speed
https://volvoforums.com/forum/volvo-...up-pics-51244/
Special Tool, Home Made
Home made special tool! - Volvo Forums - Volvo Enthusiasts Forum
Stalling Randomly / Will Not Start Sometimes
https://volvoforums.com/forum/volvo-...-stalls-55928/
Struts, Front, Guide to Changing
Strut Replacement Guide
Tailgate Trim Panel Loose?
Tailgate trim panel loose? - Volvo Forums - Volvo Enthusiasts Forum
Timing Belt and Water Pump Replacement On 850 NA - (Looks same for Turbo)
Volvo 850 Timing Belt and Water Pump Replacement | Happy Wrenching
Video: https://volvoforums.com/forum/volvo-...t-video-70149/
Transmission Flush, ATF
https://volvoforums.com/forum/volvo-...tep-step-5157/
Transmission, Manual Swap Thread
https://volvoforums.com/forum/volvo-...through-39324/
Trim Restoration - To Original Grey Color or Change To Black
Restoring Trim To Original Grey Color - Volvo Forums - Volvo Enthusiasts Forum
Turbo Boost Gauge Not Working - Cruise Control Not Working
Turbo Coolant Hose Replacement - Inlet and Outlet
https://volvoforums.com/forum/volvo-...acement-59878/
Wheel Bearing Bad - How to replace the front wheel bearings
https://volvoforums.com/forum/volvo-...rite-up-32307/
Windshield Wiper Lifting Off Of The Windshield Repair
Video: https://volvoforums.com/forum/volvo-...r-video-75987/
Yellow 850 T-5R, Rarity Numbers
Yellow t-5r rarity by numbers - Volvo Forums - Volvo Enthusiasts Forum
Last edited by mt6127; Mar 30, 2016 at 03:24 PM. Reason: Removed duplicate threads and an obsolete site, change order
Old May 8, 2010 | 10:06 PM
squiz's Avatar
thanks, i found a few things i was looking for on here.
Old Jul 12, 2010 | 09:44 AM
850_96's Avatar
this is great, very helpful!
Old Jul 7, 2011 | 04:52 AM
antonio's Avatar
i think you can repair the car by yourself.
but you need a professional tool, VOLVO VIDA DICE Diagnostic Tool hope it can help you.
Old Jun 5, 2013 | 08:45 AM
Brick850's Avatar
The control arm "volvolution" page doesnt exist any more
Old Jun 5, 2013 | 07:19 PM
Thanks, got it changed.
Old Jan 12, 2014 | 06:35 PM
xevo's Avatar
New link for the owner manuals at the Volvo site:
http://www.volvocars.com/us/top/your...s/default.aspx
Old Jan 15, 2014 | 08:01 PM
Thanks. Got it changed.
Old Mar 18, 2016 | 01:27 AM
Sheldonsmith's Avatar
My volvo AC compressor did not work well and i got confused what to do?then i surfed internet and got the name of AIR CONDITIONING REPAIR CYPRESS.They are certified as well as licensed.They have done the whole work in about half an hour.
Old Jun 1, 2016 | 08:59 AM
ryan murphy 850's Avatar
Default volvo 850 blow off valve
how hard is it to put a bov in a volvo 850 t?
Old Aug 29, 2016 | 05:45 PM
xevo's Avatar
Many of the links do not work - the ones ending in "/tm.htm"
Old Jan 6, 2020 | 11:08 PM
jetthenonturbos70's Avatar
Hi there.. This post isnt working.
rspi
Jul 14, 2020 09:26 PM
rspi
Jun 6, 2011 04:16 PM
MarkMc
Aug 22, 2008 04:52 PM
beardo265
Sep 27, 2007 09:24 AM
