Need some Help!!! Floor Vents!!
Old Jan 10, 2010 | 02:34 PM
matt01's Avatar
Default Need some Help!!! Floor Vents!!
so i fixed my passenger side without a problem, now im on the driver side, and nothings going well
i took apart the dash, when i stick a screwdriver onto the vent, it wont budge, i took off the motor the looks like it runs it, it still wont budge. there is another spine that is attached to it, but nothing else, which also turns when you move the flap.
does the car have to be running for all the vents to work?
im frustrated now.
edit 1997 volvo glt with ECC
Old Jan 10, 2010 | 02:52 PM
matt01's Avatar
the motor that opens the passenger side floor vent cannot be the motor that controls the driver side too!
Old Jan 11, 2010 | 10:43 AM
fcpgroton's Avatar
Former Sponsor
No, it isn't and they should work when the car is just in the on position because they are not vacuum controlled or anything like that. Have you tried it with the car running to see for some reason that would make a difference?
Old Jan 11, 2010 | 01:07 PM
matt01's Avatar
i was changing my wheel hub at the time, so i couldent run it. but it turns out my battery was dead also, that could have been the problem.
but my initial question still stands, how do you fix the drivers side motor?
the passenger side is no problem, remove the glove box, repair the split shaft.
Lansdowne
Sep 22, 2014 01:02 AM
Jat007
Mar 7, 2014 12:26 PM
ryan29121
Oct 29, 2010 04:32 PM
Volvo850GLTOwner
Jul 17, 2008 06:53 PM
B1mmer
Dec 18, 2006 11:24 PM
