New coil springs question
Old Oct 14, 2009 | 10:27 AM
anton850t's Avatar
Default New coil springs question
I'm thinking about putting new springs on my 95 850 Turbo Wagon. I'm assuming they have never been replaced in the life of the car. I know that most guys want to lower the height of their car for performance and handling, but is it possible to actually raise the height of the car? Which springs in particular would be able to do that?
Old Oct 14, 2009 | 10:32 AM
Legendsecko87's Avatar
Hmm, I think you can just get spacers for your old springs? If not, coilovers?
gilber33's Avatar
You want to raise the height of the car from the stock height? I highly doubt your going to find aftermarket springs for the 850 model that are going to raise the car. Maybe see if you can get some XC springs in there or something?
Old Oct 14, 2009 | 10:34 AM
gilber33's Avatar
Coilovers may work, but I doubt they would go higher than the stock, mostly because they're designed for people to completely drop their cars. And that route would cost you about 1,700 dollars.
Old Oct 14, 2009 | 12:47 PM
anton850t's Avatar
Default new springs
Do the original springs settle down in height over time? Replacing with regular stock springs may raise the height slightly just because they are'nt worn in? In any case, when and if I get new springs I'll measure the height before and after. I have heard stories of guys who bought lowering springs to replace their old worn out ones and actually ended up raising the car.
Old Oct 14, 2009 | 01:24 PM
gilber33's Avatar
They do settle over time, if you put new stock springs back on, then chances are your car will be slightly higher, but they will settle also and your car will probably drop again.
kase6000
Apr 6, 2015 05:56 PM
silverstreak98
Feb 23, 2012 02:08 PM
zloetakoe
Aug 20, 2010 03:14 PM
