Newbie from Baltimore
Old Feb 11, 2008 | 09:21 AM
dariustrucker's Avatar
Default Newbie from Baltimore
Hi All,
I just bought 1995 850 GLT Wagon. We're happy to get our dream car.
The car is a bit shaky in the morning (or when its park long enough) and took a while to heat
it up. Also, the radio is not working and has 'CODE' sign showing and the dealer said that I could get the code from Volvo dealer.
Any info will be great.
Thanks,
Dan
Old Feb 11, 2008 | 05:47 PM
Default RE: Newbie from Baltimore
Is the check engine light on.
Get the code from local Volvo dealer.
I moved this to the proper section.
Old Feb 11, 2008 | 08:04 PM
JPN's Avatar
JPN
Welcome to the forum.
Please go over the following thread & the owner's manual and make sure that the scheduled maintenance has been followed, especially the timing belt & its pulleys & tensioner.
https://volvoforums.com/m_48928/tm.htm
Good luck,
JPN
Old Feb 11, 2008 | 08:29 PM
RedTurbo850's Avatar
What do you mean by shaky? Perhaps your motor mounts need to be replaced.
Regarding the heat, is the thermostat functioning correctly at all times?
Old Feb 12, 2008 | 10:54 AM
Tech,
Yes the check engine light is on.
Red,
I brought it to mechanic to check what needs to be replaced/repair and now it's not shaky anymore.
I dunno what they did, maybe just tightened something to theengine.
The thermostat is working OK.
And, another thing, the A/C is not working on 1 to 3. It's on if I put it on 4. Temp is working fine.
Hopefully, I dont have to change the whole thing.
Need guidance.
thanks alot.
Old Feb 13, 2008 | 08:28 AM
Psaboic's Avatar
I would suuggest a good tune up as a starting point. You also need to get the code read and cleared to turn off the check engine light. It will also point you to any rtemaining issues, or at least what casued a problem in the past.
Old Feb 20, 2008 | 10:41 PM
Thanks guys.
i'll have it tune up this weekend.
dan
Old Feb 20, 2008 | 11:01 PM
ORIGINAL: dariustrucker
Tech,
Red,
Need guidance.
thanks alot.
The resistor is bad.
Old Feb 21, 2008 | 02:36 AM
JPN's Avatar
JPN
FYR.
JPN
[IMG]local://upfiles/6892/2C74DD4399204763A6B0E2BF8A4B32D4.jpg[/IMG]
[IMG]local://upfiles/6892/EAAA0A794A714A9990BF139B2C6B58B0.jpg[/IMG]
[IMG]local://upfiles/6892/13267D87A79A4F6B852A7DB0F80B5E2E.jpg[/IMG]
Old Feb 21, 2008 | 01:32 PM
green850's Avatar
where inbaltimore are you from?
i live in annapolis
Old Feb 24, 2008 | 08:16 AM
Thanks for the infos.
I'm in Baltimore city, Charles Village. I see a lot of Volvo here (esp. 850 Wagons).
dan
Shakil Crazzy
Mar 24, 2013 12:40 PM
rollerskatenate
North East
Oct 22, 2010 09:21 AM
gxwalsh
Jul 20, 2010 10:20 AM
rollerskatenate
North East
Oct 31, 2009 12:37 AM
Rangerrick13
Jan 29, 2008 10:23 AM
