no a/c or interior lights
Old Feb 8, 2006 | 05:26 AM
rocknroll_1950's Avatar
Default no a/c or interior lights
a couple of weeks ago my a/c and my interior lighting stopped working im pretty sure the same day. every time an interior light should go on the door chime does. the door chime also rings about 6-7 times when you turn on the ignition. is this an error code?
oO JOSH Oo
Old Feb 11, 2006 | 05:13 PM
Default RE: no a/c or interior lights
Did you check all the fuses?
Old Feb 12, 2006 | 11:15 PM
i checked the a/c and interior light fuses and they were ok.
oO JOSH Oo
Old Feb 12, 2006 | 11:26 PM
Is it like that with all the doors or only the Drivers door?
Old Feb 18, 2006 | 01:35 AM
all doors, glove compartment, and the vanity mirror light. basically when ever a light should be on the door chime goes off till that light should be off.
i re-counted the amount of door chimes when you turn on the ignition and it chimes 8 times.
oO JOSH Oo
Old Feb 18, 2006 | 09:19 AM
That doesn't mean anything with the chimes.
You have a power loss to the lights. You will need to find a wiring diagram and follow from the power source out to the lights.
nationm
Sep 10, 2006 01:51 PM
kmkrueger
Aug 22, 2006 09:36 PM
mr.zorak
Aug 14, 2006 01:05 AM
thullz
May 13, 2006 06:46 PM
kosta203
Jun 27, 2005 06:38 PM
