Oil in overflow tank??????????????
Old Apr 18, 2008 | 03:09 AM
850guy's Avatar
Default Oil in overflow tank??????????????
Got an 850 sedan auto and today when I came home, I noticed the overflow tank had oil in it and car is not overheating still drives fine, its not straight 100% oil its like little droplets. Any idea what my problem is or whats causing it??
Old Apr 18, 2008 | 08:35 AM
Psaboic's Avatar
Default RE: Oil in overflow tank??????????????
I'm thinking leaky head gasket.....
Old Apr 18, 2008 | 08:43 AM
JimKW's Avatar
I think it could be radiator but worse case scenario would be Head Gasket.
Old Apr 18, 2008 | 10:58 AM
JPN's Avatar
JPN
Have the engine compression-tested. If it tests good, the oil cooler has a leak in the radiator in which case you may want to replace the radiator.
JPN
Old Apr 18, 2008 | 06:34 PM
Ozark Lee's Avatar
Turbo or non turbo? If you have a turbo my guess is that the oil cooler line in the radiator has failed. If you have a non turbo and an automatic transmission the transmission oil cooler in the radiator may have failed. Are you sure it is engine oil or is it ATF?
How does your engine oil look? If you have the automatic, how does yourtransmission fluidlook? Those are alsoclues.
...Lee
Old Apr 19, 2008 | 10:32 AM
Psaboic's Avatar
Good point on the compression test. That should tell you if it is the head gasket or not
Glenn
jimbo48
Feb 21, 2013 01:57 PM
gilbreen
Nov 5, 2012 08:38 PM
gatorrac
May 4, 2012 09:06 PM
850guy
Engine & Internal
Apr 18, 2008 08:15 PM
Carbuff
Sep 14, 2005 08:41 PM
