Poor Acceleration, No Power! Please Help!
Old Mar 26, 2013 | 07:37 PM
mal81394's Avatar
Default Poor Acceleration, No Power! Please Help!
Love this car but it is making me very frustrated. I have a max speed of 50-55 mph highway and 35 around town. Engine sounds fine, transmission shifts, everything seems fine except for the fact it takes almost 4000rpms to stay at 55mph which never happened before. Just replaced spark plugs, wires, cap and rotor and no luck and no engine light or codes except for an oxygen sensor code PO172 but didn't think that would cause this unless I'm wrong. Any suggestions would be great!!!
Old Mar 26, 2013 | 07:52 PM
nitrosport's Avatar
not sure, just throwing this out there....clogged cat plus bad o2 sensor?
Bad o2 will make the car run rich, that hurts performance. Maybe in combo with a clogged cat.
Did the performance go down suddenly? Or has it been gradual?
Check vacumme lines.
Old Mar 26, 2013 | 08:02 PM
mal81394's Avatar
Default poor acceleration
performance went down gradually at first but recently pretty suddenly as you can tell by my top speed. I have read about possibly a clogged cat you think that is it? The front 02 sensor has been replaced but not the rear.
Old Mar 26, 2013 | 08:03 PM
mal81394's Avatar
Default bad acceleration
oh, all new vacuum lines and new pcv system just replaced also.
Old Mar 26, 2013 | 10:54 PM
Are we talking about an 850 ?? Which engine ?? Manual or automatic ??
It would be nice if you added this info to your "signature" so when you forget to tell people it's already there.
Did you have the problem before the PCV, vac lines, plugs, wires ....
Easier way to ask would be did it start after you did something ??
4,000 rpm at 55 mph ... can you feel it shift into fourth (if it's auto) or are you in third ??
If third you have a performance issue if you're positive it's going into fourth then the trans has to be slipping.
If it's a turbo try having it running and thumb the throttle open a couple times and see if the intercooler hose from the top of the radiator to the throttle body area collapses.
After a streatch of highway driving, look under the car and see if the cat is RED.
Old Mar 26, 2013 | 11:05 PM
mal81394's Avatar
850, non turbo, automatic, The problem didn't start until after I fixed a oil leak about two weeks ago on the cam seals. The pcv system was replaced before that. And then the plugs wires etc were replaced today. I am pretty sure 3rd gear. I would have to drive it to be sure but I think third especially because of the hills around. And for rspi, the cat didn't seem to be red when I looked. I do have code po172, possible oxy sensor and bad cat causing all this bad performance?
Old Mar 26, 2013 | 11:15 PM
http://www.matthewsvolvosite.com/for...pic.php?t=6283
Maybe a vac line came off and it's still hanging ??
Old Mar 26, 2013 | 11:23 PM
mal81394's Avatar
Thanks, ill double check the lines. Anybody else have this problem and know what it is?
Old Mar 27, 2013 | 08:23 AM
boxpin's Avatar
When the cam seal was replaced...which one was it? Did you have to remove the timing belt?
Old Mar 27, 2013 | 09:09 PM
mal81394's Avatar
Yes I did have to remove the timing belt.
Old Mar 28, 2013 | 11:33 PM
mal81394's Avatar
Could the timing be out slightly or would it not even run if it was?
chrome2386
May 28, 2013 09:56 PM
swsail
Jun 11, 2006 10:16 PM
pisque
May 19, 2006 11:31 PM
pisque
Aug 21, 2005 09:52 AM
Mcgurk
Dec 16, 2004 09:57 PM
