RE: GAS TANK LEAKING
Old Nov 13, 2008 | 06:46 PM
jhnmartin's Avatar
Default RE: GAS TANK LEAKING
Thanks for all the responses.. does anyone know how labor intensive it is to replace the upper filler neck hose(s) if they are the culprit. i'm hoping i dont have to drop the entire tank! might be time to invest in chilton manual or something similar....anysuggestions. thanks again!!
Old Nov 13, 2008 | 06:50 PM
Sometimes you can sneak the old hose out and new one in with out removing the tank. It all depends on the angle of the clamps.
Old Nov 13, 2008 | 06:53 PM
jhnmartin's Avatar
SWEET!!!
Old Nov 13, 2008 | 06:54 PM
I hope it is to where you can get to them. One you will access through the fuel pump access hole. The other one you will get from the side of the tank.
Old Nov 13, 2008 | 07:18 PM
JPN's Avatar
JPN
Unless you have experience working on the fuel system, I would consider getting a little bottle of Class-B fire extinguisher just in case (in case your Volvo or the house catches on fire, your wife/girlfriend may set a fire on you[:@]). I think you can find one for $20 or so at Walmart/equivalent shop.
JPN
bobbie
Feb 18, 2011 06:19 PM
AnEskimo
Oct 7, 2010 07:28 AM
tobolate
Jan 12, 2010 10:46 PM
jhnmartin
Dec 26, 2008 11:29 PM
RedTurbo850
Jul 21, 2008 05:43 PM
