Rear Shock DIY
Old Sep 19, 2007 | 12:26 PM
speedfot's Avatar
Default Rear Shock DIY
I've looked around but I haven't found any info on this.
Does anyone have a quick link about replacing rear shocks?
Thanks in advance
Old Sep 19, 2007 | 01:37 PM
JimKW's Avatar
Default RE: Rear Shock DIY
I looked around and this is all I could find. Doesn't look too tough. Never done it myself though.
http://volvospeed.com/vs_forum/index...howtopic=66838
Old Sep 19, 2007 | 02:07 PM
wallie's Avatar
It's pretty straight forward as far as rear shocks go, the procedure in that link will show you what you need to know. There's more about it on brickboard.com if you go there and search.
One thing you might want to keep in mind is that when you go to break the bolts holding the upper shock mount in place, the two nuts that are tac welded up inside the body may break free. That's if you replace the mounts which you probably should since it's time for the shocks then those may need changing out too. Have extra hardware on hand just in case those tac welded nuts do twist off. It also helps if you have two jacks to work with.
Old Sep 19, 2007 | 02:51 PM
speedfot's Avatar
cool.
I am going to get springs and shock mounts.
One side is noticably saggin like a bad boob job!
Is there anything else I should get while I'm in there?
cya
Old Sep 19, 2007 | 03:00 PM
wallie's Avatar
That might be it, soak the shock mouning points with penetrating oil prior to.
Old Sep 19, 2007 | 03:32 PM
speedfot's Avatar
Just ordered:
Rear Shocks
Rear Springs
Rear Mounts
Rear Spring Bump Stop Retaining Pin (only 1.75. Don't know what it is but hate to get into something and then need a part).
I will then tackle this as the link makes it look easy!
Old Sep 19, 2007 | 04:20 PM
wallie's Avatar
Sounds good, did you go performance?
Old Sep 19, 2007 | 05:29 PM
speedfot's Avatar
Sorry. Did not go performance....
trying to keep the costs down.
it is just turning 160K and I have other things that will need attending. cv joint, power steering has a slow leak.
Then I am handing this down to my younger son in 9 months.
Old Sep 19, 2007 | 07:04 PM
wallie's Avatar
I hear you... I have a set of Bilstein TC shocks w/4-5k miles on them that no one in my house is using if you want or need them, pm me if you're interested.
What did you get if you don't mind me asking?
Old Sep 19, 2007 | 07:13 PM
speedfot's Avatar
KYB.... easy.. easy... don't flame me too bad..
they were 59.00 each.
Old Sep 19, 2007 | 09:17 PM
wallie's Avatar
No hey...as long as they work for you and you like them...
Old Oct 1, 2007 | 03:59 PM
speedfot's Avatar
DONE
easy job.
first time for me took 3 hours 15 minutes.
Man what a difference.
thanks for the help!
Old Oct 2, 2007 | 01:35 AM
JPN's Avatar
JPN
JPN
Old Oct 2, 2007 | 06:46 AM
wallie's Avatar
Good for you, glad to hear it went ok. Now you have to do the fronts...j/k but...you probably will if they're original and the back needed to be done.
Old Oct 2, 2007 | 08:49 AM
speedfot's Avatar
lol... yes the fronts are original but they won't get touched for another 6 months....
I actually had to get tires for the back as they were getting bald due to the poor shock/spring issues.
Also I think the job went quicker when you replace the upper shock mounts. no need to get the top nut of the shock.. .just pull the attached shock right out through the shock tower hole!
rock n roll!
Old Oct 2, 2007 | 09:12 AM
wallie's Avatar
As long as you're not "bouncing" down the road or hearing any "clunking" up front as related to struts then finish using what you got I'd say
Old Oct 2, 2007 | 10:59 AM
  #17
speedfot's Avatar
No clunking but there is just a slight bit of bouncing. just a slight bit.
However, I did look underneath and the next 2 problems are:
1. CV boots are both ripped
2. Power stearing rack back seal is leaking.
[8D]
Old Oct 2, 2007 | 12:59 PM
  #18
outblast's Avatar
Im having the same problem with one of my rear shocks on my 96 850r, didnt notice it untill my brother driving behind me pointed it out. its saging badly [&:]i might replace them with some of the ones ipdmakes. Where did you get your parts by the way speedfot?
Old Oct 2, 2007 | 02:11 PM
  #19
speedfot's Avatar
I got them from: FCP Groton
http://www.fcpgroton.com/volvo850shocks.htm
the shock mounts from them are only 15.00 each.
Make sure you get the plastic clips for the shock bumper. they are about 1.75 each.
springs were about 41.00 each.
I would suggest the rear shock mounts if you don't have an impact wrenchas it probably will save you about 40 minutes to an hour.
good luck.
jared..mann
1998-2000 model year V70
Apr 20, 2013 04:33 PM
paul1149
Sep 6, 2012 11:20 AM
oconnomo
Aug 7, 2009 02:05 PM
floryed
Sep 1, 2005 08:47 PM
