Removing Radio... need help
Old Dec 8, 2005 | 10:13 PM
ERWest's Avatar
Default Removing Radio... need help
I have pushed in the pins and pulled them out as far as they will go...but the radio will not budge.
Is there anything else holding it in. All the help sites says that all I need to remove the factory radio is to pull out the tabs.
Please help... it will not let go.
E[]
Old Dec 9, 2005 | 12:20 AM
Default RE: Removing Radio... need help
The radio is probably just stuck from age. Give it a good tug.
Nothing else holds it in.
Old Dec 9, 2005 | 01:11 AM
ERWest's Avatar
A little tug did not work... but you were right that was all holding it in... had to use a wide long knife to WEDGE it free... it was really STUCK. THANKS SOOOOOOOOOOOOO MUCH!!!!!1
Old Dec 9, 2005 | 08:37 PM
No problem anytime.
keaunym
Mar 28, 2009 08:50 AM
axelm
Nov 6, 2008 04:31 PM
wjkjr
Feb 2, 2008 01:55 AM
