Replacing balast resistor
Old Sep 26, 2006 | 04:27 PM
Dads850's Avatar
Default Replacing balast resistor
Okay, I'm pulling a 418 code and on suggestion I purchased a new ecc ballast resistor. After doing some searching, I noticed a lot of threads about the actual blower being a culprit causing a brand new resistor to go bad after installation. Here's my symptoms:
> Rec & A/C lights flashing
> Pulling 418 code (well, along with 417, but that's a different issue)
> The blower not strong at all, but after a non-specific period of time, will work
Question is, do I need to replace the blower too? If I do need one, then so be it, but I'm really very strapped cash wise (stupid electric & gas company) and really can't afford a new blower if I don't need one.
Old Sep 26, 2006 | 05:27 PM
MikeySq's Avatar
Default RE: Replacing balast resistor
just a shot in the dark if it spins the windings are probably good, if you take the blower motor apart check the bearings to see if it spins freely(oil it maybe) and inspect the brushes to see if they're OK
-Mike
Old Sep 26, 2006 | 09:12 PM
Those are classic signs of a bad Blower motor.
Old Sep 27, 2006 | 04:42 PM
Dads850's Avatar
Damn. I was hoping I didn't need to replace the blower itself.
Old Sep 27, 2006 | 09:05 PM
Usually when the blower motor goes bad it pulls way to many Amps and then the A/C computer turns the motor off.
Old Sep 29, 2006 | 12:56 AM
Dads850's Avatar
The A/C system? It does it if the A/C is on or off - last time was when the heater was on. Does that make a difference?
Old Sep 29, 2006 | 09:38 PM
It will do it anytime you try to use the Blower motor.
Evo 850
Nov 24, 2007 05:25 PM
robsons
Nov 16, 2007 01:05 AM
85 760Turbo
Feb 16, 2006 10:13 PM
85 760Turbo
Feb 13, 2006 09:52 PM
