Roof Leak
Old Aug 16, 2008 | 10:03 AM
aaron.t1's Avatar
Default Roof Leak
Hello everyone,
I am a new member here and this is my first post.
I was wondering if any other 850 owners have had a problem with the roof leaking. Its not leaking from the sun roof, but from the rubber gaskets on the sides of the roof.
I would like to fix this problem myself, but I would like to get some advice if possible......
Thank You.
Old Aug 16, 2008 | 10:24 AM
Default RE: Roof Leak
I would look at the sunroof drains under the headliner.
Old Aug 16, 2008 | 11:12 AM
aaron.t1's Avatar
Its actually leakingin the roof of thethe passenger side back seat.... When I woke up this morning the inside of my roof was soaked all along the back seat passenger side.
Old Aug 16, 2008 | 12:22 PM
Thedrain hose might have come off. Or the glass itself is leaking and draining out of the normal drain area.
Old Aug 17, 2008 | 01:43 AM
Quick Brick's Avatar
The leak that The Anvil had was at the front of the moon roof glass and was leaking right above my head. A little clear silicone around the leading edge and no more leak.
I also think you may have lost a drain pipe.
Old Aug 17, 2008 | 09:00 AM
Psaboic's Avatar
If you haven't lost a drain hose, one is most likely clogged. Either way, when you get into it, you will want to make sure everything the seals are intact and not twisted/torn, etc.... just my .02
hovonogila
May 16, 2019 02:28 AM
Old_Volvo_Fan
Nov 12, 2008 04:48 PM
850forum
Sep 30, 2008 05:43 PM
etype38
May 29, 2008 07:40 AM
mesaview
Nov 27, 2006 02:36 PM
