RPM sensor
Old Oct 9, 2006 | 11:23 PM
hillfolk's Avatar
Default RPM sensor
Can anyone tell me if the rpm mag pick up should be strongly magnetic? I pulled mine due to intermittent rpm signal code and found it to be quite weak. It would barely attract a small screwdriver when held close. I'm curious if it gets weak with time and causes a faulty p/u signal.
1993 850 GLT
Old Oct 10, 2006 | 12:02 AM
Default RE: RPM sensor
It works electronically.
Old Oct 10, 2006 | 12:08 AM
hillfolk's Avatar
Hi Tech,
could you elaborate on that? I'm used to the magnetic P/U style that measure hertz as a ferrous tooth passes across the P/U.
Old Oct 10, 2006 | 09:36 PM
They really aren't magnetic.
They just measure the distance in the Other piece. Mostly by electric. If it has any magnetic feild then it should be when the car is running only.
Gullfisk
Oct 11, 2022 10:18 PM
Gullfisk
Feb 16, 2012 04:24 PM
mccuisb1
Mar 14, 2009 10:46 AM
Dg90Volvo740GLE
Oct 27, 2008 12:33 AM
