Shift Button
Old Nov 1, 2009 | 09:59 PM
Default Shift Button
I no longer have to push in my shift button to change gears. From park or any other location. Should I be worried about anything or just enjoy the Slap Stick?
Old Nov 1, 2009 | 10:05 PM
gilber33's Avatar
On your 850? Do you have to push it in to get out of park? I've never had to push my button in to go from neutral to drive to reverse, but from park I had to.
Old Nov 1, 2009 | 10:09 PM
If it was my car I would fix it. I have had my son pull my van out of park and hit a parked car.
Old Nov 1, 2009 | 10:15 PM
gilber33's Avatar
Luckily, I'm the only one that drives my car, sometimes I'm tempted to pull it out of park, but I just slap my hand and tell myself no.
Old Nov 1, 2009 | 11:15 PM
ajwgator's Avatar
Default Tips on fixing shift button
Tech, my shift button on a 98 V70XC AWD is cracked on one side and sticks in after pushing it to shift out of park. Do you have any tips or technices on removing it to repair or replace? Can't seem to find anything in a search about doing this on an automatic shifter. Thanks in advance.
Old Nov 2, 2009 | 07:29 PM
Yes I have a repair but you have to find an old bad 850 ****. The ones that the outside falls apart on. Then I can post how to do it.
That will be the first time I post how to do it.
Old Nov 3, 2009 | 10:48 AM
So where is the problem on mine? In the shift ****, in the center console, where? Is it a simple pin missing or do I need to replace a part. Safety First!
Yesterday it wasn't all the way in D and was between D & 3 and it went into limp home mode. Up arrow flashing and it popped a P730 code (CEL). It drove the rest of the way home fine but did feel like it was slipping when I started off. I reset the code and all is well now.
Old Nov 4, 2009 | 08:12 PM
Something may be stuck. You will have to get in there and inspect.
Old Nov 5, 2009 | 09:54 AM
The problem with NOT HAVING TO PUSH THE BUTTON is likely in the center console?
Old Nov 5, 2009 | 06:40 PM
Nope usually something in the shifter area.
schmuecker
May 19, 2011 06:45 PM
elcs70
Feb 12, 2011 07:40 PM
volvoist3021
Jul 31, 2009 01:01 PM
ross83
Dec 4, 2008 03:55 AM
fast850r
Jul 26, 2005 09:48 AM
