Side Marker Lights from S70
Finally a nice S70 in the yard. It has the side finder marker lights. Thinking about snagging them from my T-5R. Where does the wire for them connect. I seen that they fed into the fender but don't know where the other end goes. Also, are they plug and play.
Looks like someone was planing to come back for them because they were unplugged and setting on the cabin air box. I figure someone got distracted and forgot them.
Chances are, it's not. You splice them in with the turn signal wires, and then run the side marker harness through the fender.
HOW TO ON IPD'S WEBSITE
It's nice IPD has the wiring kit but I really wish them wouldn't include those blue splice blocks. Those are really cheap and easy to install but you pay for it in a couple years when moisture and in my area salt get into the connection and end up wicking up the wire in both directions corroding everything it touches and causing excessive resistance to current. They are OK inside a car but not anyplace there is any chance of moisture. The worst is people who use them when doing trailer wiring installations. It's a nightmare trying to cut out and splice in good wire a couple years later when the owner has no rear lights.
But the side marker/turn addition is a great addition. I wish there was a covert way to add cornering lights.
I went and picked up those lights. I also pulled wires from door lights. I'll install them one day, maybe next month. ![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
I wish someone made a double wire plug so I could just unplug the blinkers, plug in the splice plug, plug the wire for the signal in the back of the splice plug and be done with it.
#17
When i installed my aftermarket headlights and corner lights I made my own pigtail that just plugged in between the marker and corner light that had wires coming off for the extra stuff.
My headlights have LED's in them and then the Halo's. Also tapped in there for the fender lights as well.
#18
