Smoke coming out of exhaust 95 855t
Old Sep 16, 2008 | 02:17 PM
outdoor7or24's Avatar
Default Smoke coming out of exhaust 95 855t
Folks, 1995 855 turbo.
Just got done fixing thermostat, temp sensor, cleaned idle air valve, cleaned throttle body, replaced upper turbo/throttle body hose.
Car has been sitting for almost 2 weeks since I have started it, but now white smoke is coming out of the exhaust. I used carb cleaner when cleaning idle air valve and throttle body (tb was dirty on the intake side!). I let it dry out for a few mins before putting it back together.
Starts up and no more surging, no more cooling fan coming on, or reading running temp as soon as I start it up (temp sensor fixed it), but now I get some white smoke coming out of the exhaust. Is this normal when you clean the throttle body?
Oh, I felt the upper coolant hose to make sure I felt pressure when squezing and i did. Also, I noticed some smoke coming out of the 'honey comb' type thing that connects to the turbo and then exhaust downpipe. I guess that is where I am smelling exhaust fumes from. Maybe it is due to upper and lower torque bushings shot???
Here is a video on youtube of the smoke.
http://www.youtube.com/v/_7YLtiDnS4M
<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/_7YLtiDnS4M"> </param> <embed src="http://www.youtube.com/v/_7YLtiDnS4M" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
Old Sep 16, 2008 | 06:43 PM
Default RE: Smoke coming out of exhaust 95 855t
Did you take it for a drive before seeing the smoke?
Does it still smoke after driving?
There might be a bad or clogged hose in the vent system.
Old Sep 16, 2008 | 07:09 PM
Tech, I saw the smoke as soon as I started it up. The only thing I could think of is the carb spray loosened up some junk and it is burning off.
It is still smoking after driving, I'll see if it is still smoking after a test run this evening, I did not want to push it with it smoking.
With 153,000 on the odometer, it may be time to replace the pcv system.
Is there any way to clean the pvc system without removing? Seafoam???
Old Sep 16, 2008 | 07:21 PM
Seafoam might help a little in the oil but I am not sure I have never tried it.
Also make sure none of the hoses are bad. If one is bad that would cause it to smoke as well.
Old Sep 16, 2008 | 07:25 PM
Tech, when you say hoses, you mean the PCV hoses right?
Old Sep 16, 2008 | 07:26 PM
Yes there is also one at the induction hose just before it attaches to the front of the turbo check that one to.
Old Sep 16, 2008 | 07:28 PM
Would a bad turbo cause smoke?
Thanks for the help!
Old Sep 16, 2008 | 07:43 PM
Yes but the entire vent system needs to be checked first.
My wifes car has 225,00 miles original turbo.
ibified
Feb 15, 2014 10:27 AM
mayday123
Aug 3, 2013 06:24 AM
tmixdorf
Apr 12, 2013 12:23 PM
trex-7
Oct 30, 2012 10:43 AM
sly_fox
Nov 17, 2011 09:53 AM
