sound from speakers coming and going
Old Mar 23, 2010 | 02:21 PM
cakesplatter's Avatar
Default sound from speakers coming and going
Hello I recently bought a 1994 850 wagon. Its in great condition. One of the only things that I have noticed is the sound from the speakers. It seems that the left front side(driver side) works fine however the right side and back speakers only come on when I wiggle the volume **** just so or if I make a right turn they will come on! lol.
Is this a loose connection? Is this something I can fix easily? Advice please?
Thank you
Anna
Old Mar 23, 2010 | 02:55 PM
boxpin's Avatar
Sounds like a dirty volume pot (the volume control mechanism inside the radio).
If you can wiggle it around and it is scratchy or goes in and out its probably the pot. You can go to Radio Shack and get some spray tuner cleaner. Pull your volumn **** off or at least out at the balance stop and spray the cleaner down the shaft. Move the volumn control up and down, like your controlling the volumn. Do this with the radio off. Then turn on the radio and listen to your results.
If this does not fix it then your looking at a lose solder joint inside the radio which it would be cheaper to buy a replacement radio on ebay then have it repaired.
I have a black cassette player and a gray CD player if your interested. The CD player does skip over big bumps though.
Old Mar 24, 2010 | 05:47 PM
oh okay great! I will let you know if its the volume pot!
2 more questions... my sun roof does not go back all the way. the motor still works because I hear it but its like something is stuck in there...??? The other question is the back door(trunk) rattles when I go over bumps. It seems like it is the interior below the window... do you know how to fix these issues?
Thank you so much!!!
dobrosailor
Jan 16, 2010 10:21 PM
dobrosailor
Jan 12, 2010 06:20 AM
daver80
Jun 29, 2009 03:01 PM
SkagSig40
Apr 21, 2009 11:49 AM
XSive
Jun 20, 2007 05:15 PM
