Speaker popping
Speaker popping
Hi folks,
Just throwing this out. What could cause the left front door speaker to pop when the stereo is turned up around halfway or a little more? I've already swapped speakers and it still does it so it is not the speaker, and I have also checked the speaker connection and they are clean and tight?
Radio maybe, or amplifier? System is factory stock except for speakers which were replaced about two years ago.
Glenn
Glenn
Amp (if you have one) is located right in front of the heater core, between the heater core and the radio. Mounted to the center console hump.
Popping typically comes from the amp or internal radio amp, not the wiring (unless the wiring is grounded or shorted somewhere but unlikely).
Pull the radio and check the impedance of the speakers and impedance to ground.
If you have an amp the harness will go from the radio to the amp and from the amp back up to the radio where you can unplug it from the car. Its very easy to bypass amps in these. If you do have an amp, unplug it and plug the radio directly into the car harness and test. If the pop is gone, its the amp. If still there and you have a second radio to test with, try it.
Back to the speakers. If they turn out fine then its going to be the amp or finals in the radio. Both would require repair. If the speakers are grounded or shorted, find and replace or fix it.
