speedometer works- odometer doesn't
There is a very small nylon gear that turns the odometer that has broken. A new gear is $25 and there are instructions on this forum for the job. I've done several successfully.
https://volvoforums.com/forum/showth...er+gear+repair
And here is a link to the gear. These seem to break on all the 850s at some time.
http://www.fcpgroton.com/product-exe.../Odometer+Gear
https://volvoforums.com/forum/showthread.php?t=15644&
highlight=odometer+gear+repair
I've been reading the posts on it ('cause I'm getting ready to do it myself) and it looks like it's just a time consuming thing, especially if you need to roll the odometer to the correct mileage. Just be careful when moving the center cluster so as not to scratch it – and your hands - up. While you’re in there, might as well replace any blown bulbs, too.
Did mine in April. I removed the whole dash (about 8 more screws ;mostly to remove glovebox) ; Well worth the extra 25 min., because you will have total access to the cluster without distorting the dash. Be sure to disconnect battery before you begin and don't forget to remove the wire to the pass. airbag. Simple job, just take your time and be patient reinstalling the dash for a perfect fit.
blackbrick
2001-2013 model year V70
08-14-2014 07:11 PM
