Sway bar issue
Old Dec 5, 2013 | 08:19 PM
Phil 850's Avatar
Default Sway bar issue
I was driving yesterday and heard a bang so I looked under the car and found that the bolt/threaded part of the lower sway bar link on the passenger side had sheared off. This was an easy fix but could have been bad if the end of the rod had gotten jammed in the wheel. Just telling everyone to check these once in a while. I had replaced this with the lowest price one from IPD about a year ago.
Old Dec 6, 2013 | 08:12 AM
Yikes! I don't think you could see anything going bad with situation like that.
Old Dec 6, 2013 | 04:24 PM
They just break from time to time. What I don't like is no matter where you go you don't get ones that are grease-able. I dropped a bit over 50 bucks ea on a set of MOOG links and they aren't grease-able and they came in a sealed bag with German on it. I'm thinking they're the OEMs you'd get at Volvo just repackaged. They were thicker then the one's I replaced thought.
Old Dec 6, 2013 | 04:38 PM
Phil 850's Avatar
I do miss being able to grease things instead of just throwing it away and installing a new part. The part on this that bothers me is it was the bolt part it self that snapped and I can still move the ball joint in the end part and it feels OK. I put in a new one yesterday when I got home from work and when I took out the old one I could see that it was slightly bent.
urdrwho
Nov 23, 2014 09:49 PM
MikeNorris
Nov 9, 2005 01:29 AM
ray hummell
Sep 30, 2005 09:22 PM
dhines46
Jun 6, 2005 12:17 AM
RocknTommy
May 20, 2005 04:40 PM
