Terrible Dash Rattle at Speed
Old Jan 22, 2017 | 11:02 PM
Luke Woessner's Avatar
Exclamation Terrible Dash Rattle at Speed
*FIXED* My 96' 850 has developed a terrible rattling some where in the dashboard in front of the drivers seat that only appears over 45-50 mph. There's no rattle of any sort at idle, revving in neutral, or at lower speeds, just when at speeds over 45-50 mph. It sounds like a bee to be honest! I have to make a 3 hour road trip this upcoming Friday at freeway speed and my nerves/sanity may wear thin after listening to the worlds loudest bee under my dash for that long each way... (Not an actual bee, I checked...) Any help is greatly appreciated!
-Luke
Old Jan 29, 2017 | 10:07 PM
gdog's Avatar
Are your dash mounts broken? Common issue on these cars.
Old Jan 29, 2017 | 10:32 PM
*FIXED* It wasn't the dash at all... The windshield seal trim along the top had a loose edge that was flapping in the wind a little bit whenever the wind caught it or if I went at speeds above 50 mph. A little plastic to metal adhesive and some working in and it's all fixed now. Tested it doing 85 on an empty freeway. No rattle whatsoever.
Old Jan 29, 2017 | 10:54 PM
gdog's Avatar
Wow, that's funny.
When I first bought my 855T it had a similar issue, but it was very high pitched squeal, and it only happened above 80-85 mph or so. It was driving me nuts trying to figure out where it was coming from. I even suspected the windshield seal too, but I taped if off and the noise was still there; thought it was the sunroof seal, etc.
Finally looking through the PO's receipts, I see he just had the windshield replaced just before I bought it. So I take it back to the glass place (and kinda pretended I was the PO) and tell them about this crazy squealing noise, and ask them if they've ever heard of such a thing. He says, "Yep, let me take a look at it"... Same thing; he re-glued the outer seal and noise was gone..
Old Feb 3, 2017 | 04:59 PM
boxpin's Avatar
Weather strip at the top of the windshield.
(Edit: saw you found it.)
joejoecat
Sep 11, 2010 01:37 PM
wcrowder
Feb 18, 2010 06:50 AM
1950td
May 12, 2008 05:59 PM
parmbrust
Nov 4, 2007 02:28 PM
bigreis
Oct 12, 2006 12:06 AM
