timing belt questions
Old May 2, 2015 | 04:03 PM
jocoman's Avatar
Default timing belt questions
Hi folks
I could use a few opinions.
I have a 97 850 wagon with the B5254T with 120000 km or 75000 miles.
The timing belt I believe is original.
1. Should i change it out now?
2. should i change out the water pump at the same time?
3. what about the belt idler and belt tensioner?
4. what about the actuator?
Thanks for your options.
Jim
Old May 2, 2015 | 06:37 PM
Timing belts are assumed to be good for 75K (or 100K depending on model) OR... 7 years. If you have a 18 year old timing belt in your car - change it right away! Most "kits" for timing belt changes include a water pump, idler and tensioner. Since you have the nose all opened up, its also a good time to do cam seals, intermediate shaft seal and the serpentine belt. Do it right and don't worry for the next 75K miles... a full kit goes for about $300 at FCP Euro (double that if you want Volvo parts).
Old May 2, 2015 | 10:49 PM
boxpin's Avatar
Very simple. If you change your belt, change everything you just mentioned.
Old May 5, 2015 | 10:09 PM
Yesterday. I never change seals that are not leaking.
Old May 6, 2015 | 10:25 AM
boxpin's Avatar
If your there and it takes a couple more minutes and a few bucks more to replace the seals, why not? You would not give it a second thought if you were changing the clutch, you would change the rear main. Leaking or not. Your there...do it.
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
