Special socket to remove strut????
Old Nov 9, 2009 | 08:43 AM
mercb's Avatar
Default Special socket to remove strut????
Does anyone know if there is a special socket needed to remove the strut from the spring on a 2000 S80 T6?
Had a local mechanic attempt the job, he just called and said he can't replace my struts because a "special socket" is needed which he doesn't have!!!
Old Nov 9, 2009 | 07:31 PM
Yes you need one. But can be done without it.
Old Nov 10, 2009 | 12:23 AM
mercb's Avatar
Tell me more!
Do you know of any links that give step by step?
Can I get that tool somewhere?
Where exactly is the nut or whatever that requires this special socket and how do I remove it without the special tool???
Old Nov 10, 2009 | 12:31 AM
mercb's Avatar
I just did a search on the internet, is this the tool I need?
http://www.ipdusa.com/Volvo-S70V70-1...p-128-730-871/
How can I remove it without this tool?
Would a Goodyear garage have this tool?
My plan was to remove them from the car myself and have Goodyear remove the old struts from the spring and install the new ones, I would then install them myself on the car. Or will I not be able to remove the strut/spring assembly from the car without this tool???
Old Nov 10, 2009 | 08:15 PM
They can tap the nut with an air chisel. Or they should be able to use a pipe wrench or channel locks.
I took an old socket and cut 4 notches out to make it for the nut.
nhadoulis
Mar 2, 2014 10:03 PM
daver80
Feb 7, 2013 10:06 AM
RJSV70
2001-2013 model year V70
Dec 6, 2012 06:10 AM
CltSon
Jul 5, 2007 08:46 PM
go2sharks
Jun 2, 2007 11:00 AM
