Transmission Auxiliary Cooler
Old Jul 4, 2013 | 11:12 PM
  #21
1995Volvo850's Avatar
Originally Posted by ffmeltdown
Highly unlikely. Manual transmissions do not generate the heat that an automatic does. I have never seen one on a manual transmission.
That's what I figured. If it did, I don't even know what would pump the oil through the cooler.
I was curious whether or not the manual transmission equipped 850s have the same radiators as the automatics.
Old Nov 28, 2013 | 01:53 AM
  #22
gdog's Avatar
Originally Posted by gilber33
Found this thread via a search but gilber's link appears to have been moved; pretty sure this is the new link:
Volvo Performance Repairs And Modifications
FYI..
Old Nov 28, 2013 | 01:57 AM
  #23
gdog's Avatar
I'll finish the fittings tomorrow and post the pics of everything installed. I plan on splicing into the top cooler line. The proposed fluid flow is from the trans, to the remote filter housing, from the remote filter housing to the aux cooler, from the auxiliary cooler to the "in" hose for the factory transmission cooler ( top hose).
This is all assuming that the transmission fluid flow for my 95 850 goes from the top of the factory cooler to the bottom of the cooler back to the transmission. I'll know for sure tomorrow!
Any suggestions? Thanks!
Nice writeup! Thanks!
How's it working for you?
Old Nov 28, 2013 | 09:12 AM
  #24
ffmeltdown's Avatar
Actually, I haven't finished the install Things have been real busy for me and the family. I'll make sure I finish this thread soon though. Sorry for the delay!
Respectfully
Tom
Old Nov 29, 2013 | 10:15 PM
  #25
Most places will carry one radiator that has both the transmission and engine oil coolers. If it's not a turbo you just leave the plugs in the engine oil cooler ports. If it's not an automatic again you just leave the plugs in the cooler ports on the transmission cooler.
The same radiator will fit them all. It is sometimes cheaper to get a radiator with just the coolers you need or don't need.
As for temperature, some of the coolers have thermostats and bypass the fluid until a certain temp is reached (usually 160/180). That way it doesn't matter if the cooler is pre or post radiator. The fluid still gets warmed up by the radiator and the aux cooler will only shed heat if it's needed.
Or you can add one on.
izik
Jul 29, 2009 04:55 AM
jennifercray
Jul 19, 2009 08:00 PM
heyma
Jun 8, 2009 09:12 PM
CltSon
Jul 5, 2007 08:46 PM
hawaiiS40
Mar 11, 2007 07:41 PM
