Transmission Swap
#22
#25
Yeah, to make that work, you'd have to re- do the whole ABS system... I believe 96 is when they went to the setup where the ABS module provides the vehicle speed signal. (as well as the switch to the ABS modules that fail all the time...)
#26
There are people on vs that when they do manual swaps they have to deal with that, and I'm pretty sure all you have to do is tap into a couple wires on the ABS module or something like that, I don't think it's to the extreme of redoing the whole ABS system. But at the same time, when you do that, the odometer is off by like 5 mph...I think.
#27
It is a mightmare from what I have been reading on VS. I wanted to put a S70 cluster in and you would have to basically do the same thing to get a 96 tranny in.
I stopped thinking about it right away!!!
The 96 and 97 you can drop in an early 98 speedo cluster and go and it all works fine.
#28
#29
One other question, probably for Tech... Maybe this should be a different thread in the S70 forum, but since we're talking swaps... I'll ask it here. I have access to the engine and transmission for a '98 S70 T-5 manual. what wiring would I need to screw around with in order to put this drivetrain into my '98 GLT automatic? is it too much of a pain to be worth it? The car it came from was too badly damaged (accident) to be fixed, but I have the wheels from it already on my car, and I'd love to turn my car INTO a T-5, but if it's too much of a PITA, I'll pass on it.
![Big Grin](https://volvoforums.com/forum/images/smilies/biggrin.gif)
#30
#32
Unfortunately, before I could ask about it, the engine and trans were cut out of it in a half- assed hack job sort of way, all cables and wires were cut... dumbasses. I'll probably wait a while and look for one with lower mileage, anyway... this one had close to 200k on it.
#34
