Trip computer displaying disappeared
Old Nov 27, 2011 | 06:19 PM
chax's Avatar
Default Trip computer displaying disappeared
I left the interior lights on last night, so had to charge the battery to get it started. After it started, I noticed that the trip computer still had the back light, but no display: nothing, on any of the settings. I'd appreciate your suggestions. Thanks.
Old Nov 27, 2011 | 06:40 PM
MattyXXL's Avatar
Try resetting the cluster by unplugging it...
Old Nov 27, 2011 | 07:03 PM
chax's Avatar
Default Would disconnecting the battery do it?
Thanks for the input! Would disconnecting the battery server the same purpose? If not, will this involve removing the cluster?
Old Nov 27, 2011 | 07:42 PM
MattyXXL's Avatar
Yes disconnecting the battery will do... make sure you leave it disconnected for atleast 5 min..
Old Nov 27, 2011 | 08:01 PM
chax's Avatar
Default I'll give it a shot.
Thanks again! I probably should disconnect the battery, anyway, since I recently replaced the MAF sensor. I'll let you know what happens.
Old Nov 27, 2011 | 08:31 PM
I made the mistake of hooking the battery up backward last winter (dark and sub zero) and killed mine. Really missed it and tried to find a way to resurrect it. Couldn't find any info on fixing one.
Ran the battery down doing something, pulled it out and charged it up, info panel came back to life. Disconnecting the battery for a while seems to reset it.
Old Nov 29, 2011 | 09:03 PM
chax's Avatar
Default Disconnecting battery worked!
Thanks, guys: disconnected the battery for about 30 minutes, and the trip computer came back to life. I would have missed it...
Old Jul 10, 2012 | 07:24 AM
Dewstain's Avatar
I don't mean to bump an old thread, but I'm having a very very similar issue to this, except mine is intermittent. Sometimes it comes on when you start the car, and sometimes it doesn't. If it comes on, chances are it will go off before you drive more than about 3 miles.
Resetting the battery would hopefully fix this as well? All the info is still there, and I can see it turn off the backlight when the wheel gets to the "off" position, so I'm assuming it's still working and that the pixels are simply not transmitting.
Mine is on an '03 V70 though.
Ned120
May 4, 2015 06:54 PM
John scherf
Jul 10, 2010 09:08 PM
v70 2.4t
May 23, 2006 12:37 AM
sbeemish
Sep 15, 2004 02:48 AM
