turbo PROBLEMS!
Old Apr 23, 2010 | 05:26 PM
garlendrix's Avatar
Default turbo PROBLEMS!
ok spent all day putting a NEW 16t on and it'd blowing oil like crazy!!! WHY????
Old Apr 23, 2010 | 05:40 PM
gilber33's Avatar
Did you replace all the gaskets that you removed? Did you put in all new copper crush washers?
Old Apr 23, 2010 | 05:44 PM
boxpin's Avatar
So you installed a new 16T and now your blowing oil where? Engine, dip stick, tail pipe, seals?
Old Apr 23, 2010 | 05:54 PM
garlendrix's Avatar
its blowin out of the exhaust BIG TIME. It collects oil in the tailpipe and sprays oil out of the air outut tube. all seal replaced
Old Apr 23, 2010 | 08:10 PM
garlendrix's Avatar
I think it has bad seals or something? it was brand new tho... did everything right and it just billows smoke and oil gathers in the tailpipe. i gotto say tho, those obx full stainless exhausts look way sexy on a wagon (imo, better than the fit for sedans). either way, i'm trying to get up with the company i got it from, hopefully they'll replace it.
Old Apr 23, 2010 | 09:09 PM
james_caza's Avatar
sorry to hear that, hope you get it all worked out. i think the obx and 16t go together quite well
Old Apr 24, 2010 | 11:07 AM
garlendrix's Avatar
ok, today i took out the turbo and discovered there was a peice of plastic in the oil return line. i took it out and cleaned it up, reinstall. start it up no smoke run it lightly back and forth in front of my house; no smoke. let it idle and take for another run a lil harder and mucho but not as much smoke as yesterday. did i blow my seal with the oil outlet plugged?
Old Apr 24, 2010 | 12:06 PM
boxpin's Avatar
Hmmm, the oil is delivered to the turbo under pressure. With the plug it must have been finding a way through the seals. Hard to say if it blew the seal or if the seal will recover. Since its new, you might survive this. I would be a bit worried about the bearing journal and lack of oil. Sounds like oil was getting there and escaping through the seals so there was some transfer, again, you might survive this. Time will tell.
Sorry to hear, its a lot of work to swap stuff out to have to do it again. Are you kicking yourself for not seeing it?
Old Apr 24, 2010 | 12:40 PM
garlendrix's Avatar
yes boxpin, i'm pretty upset with myself. it was my first experience with a turbo. it does run well and sounds great but after a few mins of running it still smokes. i dunno what to do now.
Old Apr 24, 2010 | 02:00 PM
garlendrix's Avatar
it only smokes after you heat up the engine and work the turbo. if you let it idle for a while after that, the smoke calms down. does anybody have any ideas? should this work itself out or should i swap mt 15g back in?
akabond
May 28, 2011 08:17 PM
AnEskimo
Sep 22, 2010 07:28 AM
1Gray760T
Nov 13, 2009 08:19 PM
jekelvin
Oct 5, 2006 11:36 PM
rl92821
Feb 1, 2004 12:54 PM
