Two questions about the Power Stage
Old Nov 15, 2013 | 08:44 AM
x-angel's Avatar
Default Two questions about the Power Stage
I was wondering if there is a way to test the power stage (for the heater control) using a voltmeter/multi-meter. I ask this because I will be going to the boneyard here soon to pull a cooling fan, and I was going to grab a Power Stage, but I wanted to make sure it was good before I left.
Also - does anyone know the size of that alan/hex screw that holds the Power Stage to the firewall?
Thanks in advance!
(1995 Volvo 850)
Old Nov 15, 2013 | 08:51 AM
Do you have ECC or MCC?
They are mounted in the duct work with a T15.
Old Nov 15, 2013 | 09:03 AM
x-angel's Avatar
It's an ECC
Old Nov 15, 2013 | 11:13 PM
x-angel's Avatar
well?
Old Nov 16, 2013 | 04:55 PM
It's not allen or hex but "Torx".
Attached Thumbnails Two questions about the Power Stage-torx-insert-bits-180.jpg
Old Nov 16, 2013 | 05:00 PM
Volvo ECC service info with testing procedures:
http://www.volvoclub.org.uk/tech/ser...ystem-Auto.pdf
Volvo 850 ECC climate control AC & heater system service manual
Old Nov 20, 2013 | 11:26 AM
x-angel's Avatar
Yeah didn't see that at first.
Old Nov 20, 2013 | 04:07 PM
Just didn't want you to make a mistake and go after it with an allen. I recently did my old pickups blend door motor and it was mostly by feel as you couldn't see up in there. There isn't much light or room under most dashboards.
Hopefully the info helped.
I remember something on DIY repairs to the power stage if it turns out to be the problem.
AWD - How to remanufacture your Blower powerstage yourself- final update
Cubic_Curiosity
Apr 3, 2015 12:47 AM
jbuck
Nov 16, 2011 05:48 PM
cb1313
Sep 30, 2010 07:42 AM
Frodo
May 29, 2006 05:55 PM
jfunez
Mar 5, 2006 03:16 AM
