Volvo 850, 1996 Turbo A/C Issue
Old Jul 28, 2009 | 06:26 PM
denver005's Avatar
Default Volvo 850, 1996 Turbo A/C Issue
Just recently got a tranny rebuild done. The involves quite a bit of disassembly. When I got the car back, I noticed the A/C was not working. So I took it back to the repair shop that did rebuild, and they told me the compressor has probably failed.
I am still thinking it could be a electrical problem that occured during the tranny rebuild due to the dissassembly. When I turn the A/C On, I do not hear the click or the clutch engage nor any increase in the RPM. Assuming the compressor is bad, the clutch should engage and the engine RPM should increase right?
We checked the fuses, and they look good. Any thoughts?
R
Old Jul 28, 2009 | 08:53 PM
Ozark Lee's Avatar
Start with a system pressure check. If the pressure is low it will never turn on.
If the static pressure is OK - in the 100 PSI range with the compressor off on a hot day - you may have a clutch shim problem.
...Lee
Boostwhat
Jul 15, 2011 05:02 AM
denver005
Mar 12, 2011 09:59 PM
denver005
Oct 18, 2009 01:17 PM
cyallen
May 21, 2009 07:14 PM
rfa1972
Apr 19, 2007 03:36 AM
