volvo 850 standard recirculating valve limit
Old Aug 26, 2013 | 05:44 PM
john12345's Avatar
Default volvo 850 standard recirculating valve limit
my turbo is running about 16psi i fitted a blanking plate and a dump valve. now i want a recirculating blow of valve fitted again Will the stock recirculating valve that goes on the turbo be fine running slightly higher boost or should i leave the blanking plate in and get a custom recirculating blow off valve.
Old Aug 26, 2013 | 11:38 PM
boxpin's Avatar
I ran a 18T at 18psi on a CBV. You can get a IPD HD or Forge if your worried about it.
Old Aug 27, 2013 | 01:11 PM
john12345's Avatar
when you ran 18 psi was you using the standard spring in the cbv or did you have to upgrade it to stop boost leak? i want to put my standard cbv in not sure whether to put a stronger spring in first
Old Aug 27, 2013 | 02:05 PM
boxpin's Avatar
IPD red spring.
From IPDs site:
Spring selection...
The stock spring is 8 lbs and good for upto 12 lbs of boost. The included blue spring is 10 lbs and good for up to 17 lbs of boost. The included red spring is 14 lbs and good for up to 25 lbs of boost.
I still have it if you want it. I'll sell it to you for $50 shipped conus
Crummy picture.
Heavy Duty Compressor Bypass Valve
PM me if your interested.
Kenzo
Mar 13, 2014 12:49 PM
bubba240
Forum Issues
Feb 24, 2009 08:34 AM
bzzi
Jul 5, 2008 12:37 AM
GuinnessMike
Apr 9, 2008 11:17 AM
volvogirl123
Mar 28, 2007 01:27 AM
