Volvo 850 Turbo Rear Trailing Arm Bushing
Old Mar 23, 2020 | 02:45 PM
  #21
Old Mar 23, 2020 | 03:45 PM
  #22
kawasakiz11's Avatar
No you still not got it , its a blind bolt that fits in the transverse arm it goes horizontally through the bushing holding it to the arm
then the two bolts with nuts fit through the arm holding it in place
this is what im talking about that bolt you see in center of trailing arm bush
Old Mar 23, 2020 | 05:30 PM
  #23
Ok that's pointing to what holds on the "anchor arm" but some refer to it as the trailing arm bushing others call it the delta link bushing... I've never done those before, only the trailing arm bushing that bolts to the body in front of the wheel... I'm thinking that's one of the 37 ft/lb +150deg - which would make sense since a bolt that size would not want to be torqued past 50 . Maybe you can search using the part number (9181013 = L, 9181027 = R) or call a web store or dealer and see if they can find the spec in VIDA for you.
Old Mar 23, 2020 | 07:19 PM
  #24
its not the delta link bushing that is the one on the floor in the photo,that picture is the trailing arm bush
where the blokes thumb is. that bolt is hidden and another two bolts go through to the arm with two nuts on
thats why i asked meb7070 as it says in his write up hes done it all i need is the torque and if any deg
Old Mar 24, 2020 | 06:19 AM
  #25
Hey guys is it to much to ask about the bolt in the picture , meb7070 you say you have done this job please can you help with this
does it need torque setting or not.
thanks in advance
lukaspanic
Mar 5, 2012 09:40 PM
VTBricked
Aug 20, 2011 05:45 PM
92_240_sedan
Jun 9, 2011 12:50 PM
jrmcgove
Oct 30, 2009 11:18 PM
VTBricked
Jun 24, 2009 08:15 PM
