volvo 850R turbo upgrade
Old Jun 10, 2011 | 07:04 PM
  #21
gilber33's Avatar
Originally Posted by ibified
Gilber: thanks for sharing that link: Those tunes look like they're more reasonably priced than the RICA or IPD tunes, but they also seem to get you less power. Definitely worth consideration though - THANKS!
No, they net you the same power. I think you're forgetting the owner of this company is the guy who was responsible for all of the custom tunes at IPD. These tunes are probably extremely similar to IPD's. Also, IPD tells you how HORSEPOWER you'll gain, which is extremely deceiving since horsepower is NOT the same as wheel horse power. Like your car stock is 222hp, that's probably only like 190-200whp......if that. ARD tells you what you could expect to gain WHP wise, not HP wise.
Originally Posted by Mad Matt
Not sure how you come to that conclusion. With the Stage Blue tune (Which is the tune you'd be needing with an 18T) gaining you 65WHP. That's right up there with the other tuners.
Yeah, he has way more variations of tunes than other companies before going completely custom. If I still needed a tune, I would go there. I will also be going to him for ANY reflashes I need, especially for when I eventually do water/meth.
Old Jun 11, 2011 | 01:40 AM
  #22
ibified's Avatar
I have a 16T, not an 18T, Mad Matt.
Gilber: as always, an excellent point. I havent looked at the HP numbers in depth enough yet to see how they were rating things. Thanks for the heads up though, and it's good to know that this guy knows his stuff.
Old Jun 11, 2011 | 03:47 AM
  #23
Mad Matt's Avatar
My mistake, I got confused between you running the 16T and us suggesting the OP to run an 18T.
So if you run the Green tune ("Typical gain of 40 WHP") what does that equate to BHP wise? Actually, what are the estimated drive train losses in the 850's?
Old Jun 11, 2011 | 09:21 AM
  #24
gilber33's Avatar
not sure how WHP equates to BHP. But I've heard drivetrain losses on the 850s (automatics) anywhere from 15-20%.
Old Jun 11, 2011 | 10:30 AM
  #25
ibified's Avatar
FWD vehicles typically have a drivetrain loss in a FWD car is typically 10-15% with a manual transmission. Depending on the transmission setup, figure an additional 2-5% for an automatic.
850rt5
Dec 6, 2013 05:46 PM
izinux
Oct 13, 2011 05:59 PM
denver005
Mar 12, 2011 09:59 PM
S70driver
May 15, 2006 05:02 PM
