What amp battery do I need for a 850 GLT . Saloon 1993 year?
Old Nov 14, 2019 | 03:53 AM
Vj1976's Avatar
Default What amp battery do I need for a 850 GLT . Saloon 1993 year?
Hi help Iam not sure what size battery I need for a 850 glt saloon. 1993 manufactured? If smaller battery was used before 62 amp, would this have caused damage to electric parts. Due to not enough amps, stop them working properly? Used for 3-4 years. Now replace with 72 amp battery not sure this is the correct size? Help
Old Nov 14, 2019 | 07:55 AM
here in the US batteries are rated in cold cranking amps (CCAs) - OEM for your car is 600 CCAs but 650 CCAs seems to be the most widely available at a fair price. The battery's physical size is important to match up for correct terminal placement and to ensure the lock down tab works. Looks like your year takes an H5 size battery. And no, running something with smaller capacity won't damage electrical parts, it just won't have power reserve for starting on cold days and will probably not last as long.
Old Nov 14, 2019 | 08:11 AM
tukulnana's Avatar
+1
Old Nov 14, 2019 | 04:13 PM
Vj1976's Avatar
Originally Posted by tukulnana
+1
Thanks . 62 amp battery okay for a 850 glt?
Old Nov 15, 2019 | 07:43 AM
yes, 60 Ah will work, 70 Ah is preferred, particularly if you live in a colder climate with many cold starts (say temps can go down to -10 or -15C
Volvo Batteries Guide - Amperage and Dimensions for all Volvo models
Old Nov 15, 2019 | 02:32 PM
Vj1976's Avatar
Thanks for the information appreciated
Old Dec 10, 2019 | 05:16 AM
Markas's Avatar
Hi All,
Originally mine car came with 520CCA, next when that went bang I put the 850 diesel version in which was 600CCA. I now have a 720CCA which takes up the same space as the original
Mark
volvovixen
Aug 28, 2012 03:39 PM
rainman14624
Dec 28, 2011 10:04 AM
dkvcopy
Jun 23, 2008 09:19 AM
blue_boi23
Mar 23, 2008 07:47 PM
850GLT
Sep 8, 2005 01:07 PM
