Wheel Bearing gone bad?
Old Jan 16, 2012 | 12:51 PM
triggerman's Avatar
Default Wheel Bearing gone bad?
This has not been my weekend. Car is a '95 850 10 valve N/A with about 241,000 on it. Friday night I was driving on the highway and the car started to shake and shimmy like my old Corolla used to do with a bad inner CV joint. I thought oh good the front end is getting worse.
Saturday morning I had both control arms and both out tie rod ends replaced (they were needed). On my way home I had a huge fuel leak at the rail and spent most of Saturday with that.
Sunday I went out for a nice drive with a nice tight front end again, and after a while I got a hot metal smell in the cabin, I pulled over to find nothing coming from under the hood. The front driver's side hub is really hot. I turned around and came right home, and on the way car started to chug while coming to a stop, and seemed to get worse when I applied the brakes.
This morning it drove fine for a little while, and then after a while when everything got hot, the chugging came back.
Is this a bad wheel bearing that happened to go bad right before this front end work? What else could it be?
Old Jan 16, 2012 | 01:28 PM
If you are having driveability problems do not drive the car. Check it out first. Pull the wheel and see if the wheel turns. It's likely a bad caliper or bearing. Either way you need to get it fixed before you destroy other parts of the car or have an accident.
Old Jan 17, 2012 | 12:18 AM
Ditto
If the caliper seized or froze and was able to apply that kind of pressure for you to be able to feel it dragging, the rotor should show signs of overheating (blue). If the rotor looks fairly normal it sure sounds like you have a bearing going out.
Old Jan 18, 2012 | 11:40 AM
triggerman's Avatar
Found out it's sticking caliper. Thanks for the info!
Psaboic
Jun 18, 2011 11:36 AM
jeremy4130
Oct 26, 2008 04:26 PM
GaMax2k1GLE
Jun 13, 2007 02:24 PM
mccreadys4
Dec 22, 2005 12:42 PM
alecw81
Nov 11, 2005 12:14 AM
