wrong oil
Old Jul 26, 2011 | 07:40 PM
vpatrol's Avatar
Default wrong oil
A buddy has been staying with us for a few months and I've let him use the 850 as his own while here. He changed the oil about a month ago. I've just noticed a can of diesel oil which he mistakenly bought and used in the 850.
The car runs fine but should I be worried? I've heard it can damage seals in petrol engines. I've also heard some people use it on purpose. Can I wait until the next service or should I change it now?
Old Jul 26, 2011 | 07:46 PM
trs80's Avatar
I see no problem running a diesel oil as long as it is the correct weight, ie. 5w30.
I run Shell Rotella (Shell Rotella® Products - Shell Rotella) diesel oil in my Jeep Cherokee and have been for over 3 years. The Cherokee just hit 190k miles and still runs like new. Diesel oil has a higher level of Zinc (ZDDP) and is better for flat tapet cam engines, like whats in the Cherokee.
If it bothers you, just drain and fill with fresh oil.
Old Jul 26, 2011 | 08:16 PM
vpatrol's Avatar
its 15w40 which isn't far off the recommended 10w30 or 10w40 from the castrol site. temperatures don't get that low here so probably a thicker grade then the US.
Old Jul 26, 2011 | 09:08 PM
trs80's Avatar
Thats not bad at all. Its on the heavy side but should be fine for your climate.
Old Jul 26, 2011 | 10:50 PM
ibified's Avatar
I exclusively run synthetic rotella in all my motorcycles and have no issues there either.
Old Jul 27, 2011 | 12:00 AM
vpatrol's Avatar
haven't seen the stuff in any of our shops
Old Jul 27, 2011 | 05:50 AM
jn1965's Avatar
Default it should be fine...
I got tired of buying different grades and types of oil for the
Mercedes Diesel, Jeep GC, Jeep CJ, Suburban, and the Volvos (S60 and my old 960).
I few years ago I standardized on Rotella T6 Synthetic 5W40 and all my vehicles seem happy. The oil leaks that Mobil1 Turbo Diesel oil caused in the Mercedes went away and the gassers stay cleaner as the Diesel oil has more detergents in it than regular gasser oil.
Old Jul 28, 2011 | 09:52 PM
Henry10's Avatar
That weight (15W40) is not the best oil for your winter now. On the other hand, diesel oil has some things in it that are very good for our old engines. I wouldn't worry about it.
If your car is Turbo, it is more important for the oil to be synthetic.
Old Jul 29, 2011 | 12:57 AM
vpatrol's Avatar
The temperature doesn't get below freezing often (certainly not during the day) so that weight is pretty common/popular here.
Old Jul 29, 2011 | 01:11 PM
Ovlov Lacidar's Avatar
Diesel oil in the engine is fine...as long as you start using diesel fuel.
Old Jul 29, 2011 | 02:05 PM
boxpin's Avatar
I dont think you would have any damage but I also would not leave it in there. We are talking a small amount of $ to change it....why risk it?
Here is a write-up that explains the differences.
What Is the Difference Between Gas & Diesel Engine Motor Oil? | eHow.com
BB Roller
Feb 27, 2011 06:28 PM
J Telectro
Jan 10, 2007 09:25 AM
TheVolvoMan
Jan 8, 2007 09:22 PM
grochef
Sep 8, 2005 12:14 PM
mywifescar
Apr 1, 2005 08:22 PM
